Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
My MTD B/160 starts fine but is blowing black some black smoke and seems to have lost power. Any suggestions>?
  • 391 Answers
Hello by what you are telling me the only problem this could be is that your piston rings will need to be replaced the black smoke you a noticing is oil escaping through the shaft best leave it to a mechanic goodluck
Posted on Mar 30, 2011
7.5 blowing black smoke
check fuel pressure regulater,map sensor &coolant sensor
Aug 27, 2012 | 1985 Ford F350
My yard michine is carbon up spark plug
if it is black smoke then you have a carb problem
Jul 29, 2012 | Mtd 22" Yard Machine Push Mower
Had exhaust manifold replaced since then my 2001 caravan bucks and blows black smoke little to no power
if you replaced the manifold because it was cracked the look for a plugged cat convertor..the cracked manifold was probably letting the exhaust escape..now it builds too much back pressure
Jul 24, 2012 | 2001 Dodge Caravan
2005 Ford F250 6.0 turbo diesel blows black smoke out exhaust and has no power when I try to excellerate.
1. check charge air tube,loosing boost pressure=low power and black smoke
2. check for air filter restriction,if it cant breathe it will blow smoke and run like ****
3. check for rotational drag on the turbo compressor wheel, it may be locking up causing low power and black smoke, much like cummins vgt turbo
4.oil quality,poor oil quality, ie long intervals between oil changes.
5. may have a leaking injector, not common with this style of injector but i wouldnt rule it out if nothing else checks out.....hope this helps.
Jul 21, 2012 | 2005 Ford F 250 Super Duty
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
Jul 07, 2012 | Technics SL-BD22 Turntable
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Sep 30, 2011 | Mtd Garden
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
02 hd2500 diesel lack of power changed fuel filter blows black smoke seems to run fine just no umph
is there ther diesel fuel in the oil? an injector may have gone out black smoke means to much fuel,
Sep 22, 2009 | 2002 Chevrolet Silverado 2500HD
The motor from my reciprocating saw started emitting smoke.
That small black piece, was it somewhat flat? I am thinking that it could be part of the fan or baffle. As far as the smoking when you had it apart how did the windings look on the armature and field? It is possible that this piece of plastic opened up the windings and there is a short in the electrical components. If that is the case I would suggest taking to a repair center to get is looked at. Let me know what you find
Jan 03, 2009 | Porter Cable Variable Speed Quik Change...
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
130 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
