Question about Akai LCT2716 27 in. LCD Television
Akai LCT2715 Blinking Power Light
It would seem that I have the same problem as others with the blinking power light. A crackling sound can be heard through the speakers. Before it totally cr*ped out lines appeared through the screen. After a restart it seemed to work fine for about 45 min, then the lines reappeared & grew till the screen went blank. Assuming it is the power supply issue. Can you get the your charges to refurbish & an address to ship to. Please indicate payment options also.
Thanks
    Genius:
  • 1,694 Answers
Hire a tech directly to replace all the bad capacitors on the power supply PC board.....................T.
Posted on Jan 14, 2009
My akai television won't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 16, 2014 | Akai LCT2715 27 in. LCD Television
Akai TV wont turn on right
this could be the power supply board
May 13, 2010 | Akai LCT2715 27 in. LCD Television
Have akai bought in 2006, no picno sound just red blinking light should I junk it?
NEVER!... Never, ever junk it.
Check for bad capacitors on the capacitors on the power supply.
Jan 23, 2010 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Sep 06, 2009 | Akai LCT2715 27 in. LCD Television
Tv will not turn on, makes clicking noise as the green light blin
clicking = power supply not coming up
bad power supply, or bad (shorted) part causing power supply to not come up
with a volt meter we can troubleshoot
Feb 05, 2009 | Akai LCT2715 27 in. LCD Television
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
27 akai lct2715 POWER SUPPLY
Have you had your power supply repaired? If not i can possibly help you with this issue.
Nov 07, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT2715 No Power
I have a different thread going, but saw yours and had a question. Is your light blinking steady and then off? or is it a blinking erraticly or even flickering? My bad caps (15 of them) were all on the secondary side of the PSU. I have been told (thanks to Jaimie Hernandez) if you have a steady blinking, then it is very likely that you have a bad zener diode Z3(27v/1Watt) shorted in the primary side of the power board. If that diode is shorted, it's very likely that 2 10 ohms resistors might be open, these resistors are connected to the cathode of Z3. Also check for bad caps on the Primary side.
I had a huge incentive to fix the TV, it is my wife's TV and she has been in my Man Cave since it died. How about that incentive.
Good luck
Gallagher68
Oct 19, 2008 | Akai LCT2715 27 in. LCD Television
AKAI LCT2715
Its busted. Try resetting it as a last resort, unplug the AC, wait 1 minute, then plug back in. If that doesn't work, its in need of professional service.
Jul 31, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT2716 27 in. LCD Television Logo
135 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
