Question about RCA RS2642 Neo-5 CD Changer Audio System Shelf System
I have an RCA rs2642 shelf system. It is a 5-CD changer, and none of the discs will read.
  • RCA Master
  • 2,098 Answers
Hi Joespivey,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - because of dust build-up, the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 26, 2011
A CD is stuck in disc 3 of my 5 disc changer. How do I get it out?
Disassembly may be required to get access to the stuck disc and remove it.
Mar 16, 2015 | RCA RS2664 Shelf System
CD player just says READ on it
Buy a CD cleaning kit, this will clean the plastic laser lens that is hard to get at, hopefully this will clean any dirt on the lens and bring it back to operational mode.
Mar 04, 2012 | RCA RS2640 CD Shelf System
I a home rca 5 disc cd changer it will read my cds
Hello
Hello
You have an RCA 5 disc CD changer and it reads CDS. Then what is the fault?
Jan 17, 2012 | RCA Audio Players & Recorders
RCA Shelf System 1285 manual
Retrevo has the manual here: http://www.retrevo.com/support/RCA-RS1285-manual/id/402ci676/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
Jun 14, 2011 | RCA RS1285 CD Shelf System
My 5 disc rca changer is not reading the disc, every time it say reading and then it say there is no disc.
Try to clean laser lens with CD cleaning disc. If it not helps, then Your lens must to be replaced.
Sep 06, 2009 | RCA RS2652 Shelf System
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
Cd shelf unit stuck in standby
my rca 5 disc changer stuck in standby
Dec 12, 2008 | Audio Players & Recorders
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
RCA RS2642 Neo-5 CD Changer Audio System Shelf System Logo
105 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
