Question about All-Power America All Power America APW5005 1600 PSI 16 GPM Electric Pressure Washer
The water inlet broke off. Is there a replacement part to fix? all power america apw5005
    New Friend:
I have the same problem
Posted on Jun 06, 2015
Samsung dishwasher A A A error code E03 fix
Error Code: 0E
Reason For Error Code: OVER-FLOW ERROR Overflow error
Repair and or check: Unplug the dishwasher to disconnect electrical power. If water continues to fill the tub, replace the water inlet. If filling stops when you disconnect power than replace the main power board assembly.
Parts Needed: Water inlet valve or Main power board assembly
Dec 27, 2017 | Samsung Dishwashers
AC inlet is broken on TX-SR875... How do I replace it?
A simple easy fix would be to hard wire it, solder a new cable in and secure it so it cannot be pulled out.
Feb 14, 2014 | Onkyo Audio Players & Recorders
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
Not heating water
Water Inlet Valve
First you will need to completely remove both hoses. Check and clean the screens in the hoses. Next look in the back of the water inlet valve the screens can usually be pulled out and cleaned. If all is clean and still no water, check to make sure the water inlet valve is getting power when the washer is in a fill cycle. If it does replace the water inlet valve.
Sep 28, 2012 | Washing Machines
How to replace water inlet valve on a hoover 500M washing machine?
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord.
Turn of water supply to the machine.
Disconnect the water hoses
Unscrew the screws on the rear cover and remove
Use a screwdriver to press in the inlet valves plastic locking clip
Pull the inlet valves upwards and disconnect spring clip electrical terminals
Push in new inlet valves and connect spring clip electrical terminals
Reinstall plastic locking clips
Reinstall rear cover and reinstall screws
Reinstall water hoses and turn water on
Reconnect power cord and switch power on
Aug 02, 2012 | Washing Machines
Cold water fill hose seems clogged --will fill hot water fast, but not cold ---very slow drip
take your cold water pipe off and see if there is any thing in there or it could be your inlet valve broke not had to fix swop them round and if fixs you problem just put a new cold 1 on
Jun 22, 2009 | Kenmore 22422 Top Load Washer
The water line has frozen and broke in the back of the icebox. WHat part number has to be replaced?
Hi, Is the line that is broke on the outside of the refrigerator? Is it the line that broke or the inlet valve? I am asking so I can be clear on what it is you need.
Please get model # so I can look this up for you.
Thanks
Vic
May 30, 2009 | Refrigerators
We have a old Montgomery Ward five-hundred Glass Lined hot water heater Serial # SNN 1177204708 Model # SRM33331A Type Gas NATURAL GAS PRESS IN. W.C. Input BTUH 46,000 MAX SAFE INLET 7.0 RECOVERY GPH 38.6...
I believe I had the same problem with my water heater about 15 years ago. It started with a small leak, then the tank broke flooding the room. I think it would be be best to replace the unit. Water heaters tipically have a 8-10 year life.
Mar 11, 2009 | Montgomery Ward (223600UP) Heater
LG Dishwasher ie error code problem
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
All-Power America All Power America APW5005 1600 PSI 16 GPM Electric Pressure Washer Logo
180 people viewed this question
Top All-Power America Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an All-Power America Garden Expert? Answer questions, earn points and help others
