Question about Chicago Pneumatic Air Tools & Compressors
Hearing a random cluck/grinding sound coming from the left rear when starting from a stop and usually after ive been driving for a few miles. its happens randomly and not all the time. its on a 2002 chevy trailblazer
  • 6 Answers
SOURCE: 2000 beetle will die at random times, and will not start for about 15 minutes!
this can be caused by a bad fuel filter or dirty injectors. try a bottle of fuel injector or fuel system cleaner in a tank of gas. i suggest lucas products which can be found at any parts store.
Posted on Aug 15, 2008
  • 27 Answers
SOURCE: Gauges gone crazy
Could need new instrument panel cluster but check for corrosion as the instrument panel connector
Posted on Sep 10, 2008
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Posted on May 25, 2009
Molson02536
  • 3854 Answers
SOURCE: chevy cavalier wont start randomly! makes one
Ok then, from your description and the
make/model/year of the car you have there,
it appears you've reset the VATS.
The car's security immobilizer
reader at the key switch
does not recognize the coded
chip in the ignition key any longer.
You can try to put the key
in the ignition, turn to the on position &
wait at least 10 min like that.
(Do not turn off the key switch before
10 minutes as elapsed!)
Once done, the key is re-programmed and
should allow the fuel injectors to work again.
The car would start now if corrected.
In some cases, the VATS (GM'S VEHICLE ANTI THEFT SYSTEM)
will re learn the code this way, and will then
allow the restart, however if this does not work,
then you can simply tow it to any GM vehicle dealer
to have the service department re code it.
There is a permanent solution though.
Adding the PLJX Self learning Bypass module (59.95)
will bypass the PASSLOCK system in your vehicle
for good. See this at www.PASSLOCK2.com
Good luck I hope method 1 does the trick!
Here is the 30 min relearn:
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
Posted on Dec 23, 2009
SOURCE: GE gas stove top igniters won't stop clicking
My wife just called me with the same problem - all 4 starters are clicking repeatedly - which started while the range was being cleaned.
From a Google search, this is what I found. Don't know if it will solve our issues, though wanted to share as it sounds like we may all be suffering from dirty starters (electrodes).
My surface burners keep "clicking" even after the burner is lit. There are a few things to check for.
And, to check the model number, look at the various places pointed to in the upper left of this diagram. http://www.applianceaid.com/newpics/range-model2.JPG
Posted on Dec 29, 2009
Braking results in grinding sound
I suggest you pull rear drums or have someone qualified look at rear brakes. it could of broke a spring or other brake hardware. I suggest stop driveing the car until you can inspect or have the brakes inspected..
Aug 02, 2014 | 1999 Ford Taurus
My chevy truck make a clunking noise when I put it in reverse and when I drive the truck for a while it sound like the rear end start grinding when I take off from a complete stop. What could the prob
Check drive shaft assembly for worn u-joints.if OK check for worn pinion bearings or loose pinion nut.This can all be check shaking drive shaft at each end and looking for slop in u-joints or pinion flange.
Apr 10, 2013 | 1992 Chevrolet K1500
I have a 99 mustang. I went to put it in first and drive and I heard a clucking and grinding noise coming from the rear end I'm a girl and would just Like to know what the problem is....please help
If the noise is coming from below the trunk area(by the rear wheels), It may be that the differential is probably going bad and the grinding is coming from inside the differential. Inside the differential are gears and they will grind and cluck if they are going bad or bad. The car may or may not move depending on the damage inside the differential.
Jan 18, 2013 | Cars & Trucks
1997 ford f150 grinding noise after 45mph
i never had your problem but some body i know did and they said it turned out to be the wheelbearing. so just give it a thought
Sep 05, 2012 | Ford Cars & Trucks
I have this awful clucking sound usually when making a left hand turn. I also seem to go thru tires to often for the miles I drive.
You probably need to replace the CV joint in the left wheel assembly (and maybe the one on the other side as well). Have the alignment checked as well. Hope this helps!
Jun 06, 2010 | Chrysler PT Cruiser Cars & Trucks
2005 sportsman noise in the rear area of the machine
The belt and pulleys are probably not the cause with the sound you are describing. To me it sounds more mechanical when you say grinding. Have you checked the rear dif?
Mar 17, 2017 | Polaris ATV
I have a 2008 Honda LXP purchased Novemebr 2008. It has 21000 miles on the clock. From and since 15,000 miles I heard a grinding sound when I applied the brakes after the car was stationary for over 10...
from my experience its sounds like ur front rotors may need resurfaceing...if ur doing that...may as well replace the brakes on the front as well...sometimes glazed front brake pads may make a sound but never heard of it as a grind, usually its a squeal...have ur dealer check ur rotors for hot spots in which u would need them replaced if they are overheated..also check the front pads for cracked brake pad material
Apr 09, 2009 | 2008 Honda Accord
Left tie rod problem
Sounds like it may be your left CV Joint. if it is you might as well change both sides since they have the same amount of milage on them.
A total CV joint failure = Tow to the shop. Good luck and hope this helps
Apr 09, 2009 | 1988 Toyota Camry
Clucking when turn or hit a bump!
Ive seen brake pads on those flop up and down bc of clearance btwn top and bottom of pad .. usually not dangerous and can be fixed by anti-rattle clips ( if thats what it is ) Thank You
Mar 11, 2009 | 2000 Mercury Sable
Open Questions:
Air Tools & Compressors Logo
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
