Question about Whirlpool Washing Machines
Machine will get water wash but will not rinse, or empty water water pump looks ok ,
    Sergeant:
    Champion:
  • 202 Answers
Hi.... you have a bad presure switch .... after it fills the 1st time its won't reset for the rinse
Posted on Mar 26, 2011
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Bosch Maxx WFL2260
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Mar 24, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Hotpoint washer Won't rinse
your cold water valve will be your problem or you've turned the water supply off, if the supply is not off put the machine on to the final rinse if it fills it will be the main rinse valve gone. The cold water valve is a double one with 2 solaniods. Unplug the machine turn water supply off remove fill hose there are 2 screws keeping the top on, remove them lift the lid off.undo the screws that keep the valve on, take note wiring and remove pull the black hoses off, replace with new one. The resistance of the valve will be around 3.4 kohms
Oct 07, 2007 | Washing Machines
Washing Machines Logo
22 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
