Question about Belkin TuneBase FM (F8Z049-BLK) Car Adapter, FM Transmitter, Car Mount for Apple iPod (2543448)
Fuse Model #F8Z049-BLK Fuse fell out and is lost. What kind of replacement fuse do I look for?
  • 2 more comments
  • Anonymous Sep 05, 2008
    Original fuse for Belkin F8Z049-Blk was lost. Manual does not specify replacement fuse # or specifics. Any ideas on the proper one?
    Original fuse for Belkin F8Z049-Blk was lost. Manual doesn nor indicate any info about proper replacement. Any ideas?
  • Anonymous Dec 12, 2008
    will any other fuses work or does it HAVE to be a 1 amp, 250V fuse?
  • Samantha07 Jan 30, 2009
    Where do I go to find a fuse for it?
Its actually a 7A 250V fuse. Unfortunately, I have not had any luck finding it. Also, 7A 250V fuse come in two sizes, a large and a small. So you will need the small
Posted on Feb 22, 2009
Hey dude the fuse is a 1A 250V.
Posted on Oct 17, 2008
The Belkin TuneBase (Model F8Z049-BLK) original fuse is 1A 250V. The fuse is not a standard size and is 1 inch in length. Nobody seems to carry the fuse including Radio Shack, auto part and hardware stores. They carry the 1A 250V fuse and they are 1-1/4" long. Still searching.
Posted on Feb 28, 2010
Which fuse is for the brake lights on a 2000 olds bravada? how is it labeled?
During stoplamp operation, power is supplied from the STOP LP fuse in the underhood fuse block through CKT 1540 (ORN) to the TCC/stop lamp switch. When the brake is depressed, the contacts of the TCC/stop lamp switch close, routing power to CKT 17 (WHT). CKT 17 supplies power to both the VECHMSL fuse and the stop switch contact of the hazard switch. From the VECHMSL fuse, current flows through CKT 1320 (LT BLU) to the high mount stoplamp and high mount stoplamp resistor. The ground is provided by G450 through CKT 1350 (BLK). From the stop switch contacts of the hazard switch, current flows through the turn signal switch to CKT 1418 (YEL/BLK) and CKT 1419 (DK GRN/WHT). CKT 1418 (YEL/BLK) supplies power to the LT TRN (rear) fuse (which feeds the LH rear park and turn signal lamp terminal A) through CKT 618 (YEL). Ground is provided by CKT 1350 (BLK) to G450. CKT 1419 (GRN/WHT) supplies power to the RT TRN (rear) fuse (which feeds the RH rear park and turn signal lamp terminal A) through CKT 619 (DK GRN). Ground is provided by CKT 1350 (BLK) to G450. When the left or right turn signal is turned ON, the appropriate turn signal will flash. The opposite side will remain ON in order to serve as a stoplamp when the brakes are applied.
Sep 29, 2017 | 2000 Oldsmobile Bravada
03 suburban rear blower not working
replace blower motor in rear
Jul 19, 2014 | Cars & Trucks
Hi what kind of the fuse is in this tv cause i oppened the tv and removed the fuse and now i have lost it and dont know what kind of fuse it was! Do you have any idea?
Hello
You haven't mentioned anything about your tVs brand name and model number. Anyway; in most TVs the fuse will be a glass cartridge type of 250V 3.5Amps one. OK.
Jun 16, 2011 | Televison & Video
Where can i get the glass fuse for the belkin tunebase. car shops don't seem to stock the right size
Try a local Radio Shack,ask a sales person to help.You need to know the size,milliamp ect.This is a small sale item for them so don't go at a busy time.
Jan 04, 2011 | Belkin TuneBase FM (F8Z049-BLK) Car...
02 altima wiring for all three harnesses
12V'green '+ 'ignition harness '
' STARTER'black/red '+ 'ignition harness '
' SECOND STARTER'black/yellow '+ 'ignition harness '
' IGNITION'black/red '+ 'ignition harness '
' ACCESSORY'red '+ 'ignition harness '
' SECOND ACCESSORY'white/blue '+ 'ignition harness '
' POWER LOCK'pink *7 '- 'pin 37 @ BCM by fuse box '
' POWER UNLOCK'brown *7 '- 'pin 44 @ BCM by fuse box '
' LOCK MOTOR'yellow/red ' 'pin 30 @ BCM by fuse box '
' UNLOCK MOTOR'green/white ' 'pin 23 @ BCM by fuse box '
' DISARM DEFEAT'green/red ' 'pin 31 @ BCM by fuse box '
' PARKING LIGHTS +'red/blue ' 'driver kick panel '
' HEADLIGHTS'blu (L), red/yel (R)'+ 'IPDM E/R *1 '
' DOOR TRIGGER'*2 '- 'BCM to right of fuse box '
' DOME SUPERVISION'comes on with unlock' ' '
' TRUNK/HATCH PIN'purple/white '- 'pin 18 @ BCM by fuse box '
' HOOD PIN'yellow/black '- 'hood pin switch '
'TRNK/HTCH RELEASE'red/blk or blu/red '- 'pin 76 @ BCM by fuse box '
' FCTRY ALARM ARM'pink/blue *3 '- 'driver switch in door '
'FCTRY ALRM DISARM'white/blue *3 '- 'driver switch in door '
' TACHOMETER'white/green ' 'ECM behind glove box *4 '
' SPEED SENSE'blue/yellow *5 '8 'pin 9 @ instrument cluster '
' BRAKE WIRE'red/green '+ 'brake pedal switch '
' HORN TRIGGER'green/white '- 'steering column '
' WIPERS'blu (L), blu/blk (H)'- 'wiper motor '
' LF WINDOW UP/DN'blu/red - blu/wht 'A 'driver window switch '
' RF WINDOW UP/DN'green - yellow *6 'A 'driver kick panel '
' LR WINDOW UP/DN'purple - blue 'A 'driver kick panel '
' RR WINDOW UP/DN'red/yel - yel/blk 'A 'driver kick panel '
' SUN RF OPN/CLOSE'not recommended ' ' '
' RADIO 12V'yellow/green '+ 'radio '
' RADIO GROUND' ' ' '
' RADIO SWITCH'purple '+ 'radio '
' RADIO ILLUMINATE'red/blue '+ 'radio '
' POWER ANTENNA'green '+ 'radio '
' LF SPEAKER'blu/wht - blu/red ' 'radio or amp under rear deck'
' RF SPEAKER'wht/blk - blu/blk ' 'radio or amp under rear deck'
' LR SPEAKER'grn/yel - blk/yel ' 'radio or amp under rear deck'
' RR SPEAKER'blue - red ' 'radio or amp under rear deck'
here is a wire diagram for the altima .you should be able to just buy a radio harness to attach to the factory harness with diagram of wires on back and find out what color are what on your factory wires
623.10482.150x100.nn03b.jpg 02 harness for your car from scosche
http://www.tintingbyfredjohnson.com
Dec 31, 2010 | Car Audio & Video
Honda accord compatibility
The unit should be compatible with any vehicle that has a working cigarette lighter port or 12volt power point.
May 04, 2010 | Belkin TuneBase FM (F8Z049-BLK) Car...
Stereo wiring for a 91 honda accord
1. red/blk ---------lighting switch
2.wht/yel-----------to fuse No.24 (7.5A) under hood relay box
3. yel/red---------- to fuse No. 11 (10A) Dash fuse box
4.brn/blk ----------- (--) R front speaker
red/grn ----------(+)
6. brn/blk-------------(--) L front
blu/grn
7.brn/wht -----------(--) R. Rear speaker
red/ywl-------------(+)
8. gry/wht----------(--) L..Rear
blu/yel ----------(+)
9.BLK----------------- to the ground.
Apr 05, 2010 | 1991 Honda Accord
I need operating instructions for tunebase fm model NoF8Z049eaBLK
Go to www.belkin.com and click on support center and then type in F8Z049 and it will let you download the manual.
Jan 13, 2009 | Belkin TuneBase FM (F8Z049-BLK) Car...
Belkin TuneBase FM (F8Z049-BLK) Car Adapter, FM Transmitter, Car Mount for Apple iPod (2543448) Logo
1,572 people viewed this question
Top Belkin Audio Players & Recorders Experts
ocgordy
Level 1 Expert
woodzowl307
Renee Knafel-Bullock
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
