Question about Arts & Letters Arts and Letters Express
Arts and Letters Express 7.0 will not load into a new Windows 7 machine. It worked fine on Windows XP.
I have Arts & Letters 7 and have used it for years. I now have a new 8.1 computer and I cannot download it to the new computer. Is there any solution? kimkamensky@aol.com
First hing I would check is to make sure it is compatible with 8.1. Was version 7 installed under 8.1 or an earlier flavour?
Sep 30, 2014 | Computers & Internet
Having trouble with arts & letters express 8.5 downloaded to windows 8
I figured it out. It my own fault, my computer had a bad memory stick. Once I replaced it, my Arts & Letters Express 8.5 worked perfectly. This is the best program for creating graphics.
Apr 21, 2014 | Arts & Letters Computers & Internet
Download and installation of Express 8
The software for 32-bit systems, which runs on 64 bit windows 7, is located at http://www.arts-letters.com/. A copy with license key is available for purchase.
Feb 28, 2014 | Arts & Letters Arts and Letters Express
Sims3 is incompatible
I assume you running it on Windows 7 32-Bit. Now before you trying the tips below, do make sure your computer is compatible and meet the Sims 3 requirement.
The Sims 3 can be run on a PC with Windows XP and Vista, and on a Mac. However, there is no official Windows 7-compatible version. This means that Sims 3 will not install on Windows 7 properly.
To fix this error, you need to run Sims 3 in Compatibility Mode. To do that, simply right-click the Sims 3 icon, select Properties and then select Compatibility. Then check the Run this program in compatibility mode for box and select Windows Vista or Windows XP SP3. The game should work fine.
Nov 17, 2013 | Electronic Arts Sims3 Sims 3 - Pc...
Plustek Optipro 9636T - working under Windows 7.
If you scanner only has Win XP drivers, then you have only two choices as those drivers wont work on WIN 7. One is to buy a new scanner, as you have already suggested. The other is to create a virtual machine, load WIN XP onto it, and then install the scanner drivers on the virtual machine. This should work fine as I do it for a piece of software that only works on WIN XP, however it is a bit of a inconvenience to use.
Aug 20, 2017 | Plustek OpticPro 9636T Flatbed Scanner
I just got Windows 7 and was told Outlook Express wouldn't work with that OS. So, I loaded in Eudora. Not really fond of it but then was told I could go back to Outlook Express IF I changed the...
I would suggest using Windows Live Mail, as this is what Microsoft intended when they retired Outlook Express.
You can download from: http://explore.live.com/windows-live-mail?os=other
It is a more feature rich email program than Outlook Express and should provide all needed functionality.
Jul 12, 2011 | Microsoft Computers & Internet
How to instal outlook express?
Outlook express only comes with windows xp and earlyer windows versions.
However in windows vista microsoft did replace outlook express with windows mail and
in windows 7 they left it completely out of the package.
In windows 7 you'll have to install windows mail from the windows live essentials package, wich is free to download.
Outlook express can't be installed on windows vista and 7, use windows mail instead.
Download Windows Live Essentials here: http://explore.live.com/windows-live-essentials?os=other
May 22, 2011 | Microsoft Office Professional 2007 Full...
I have multiple accounts worked fine outlook express terrible windows live,can I use outlook express in win 7?.regards
Unfortunately , Windows 7 doesn't support Outlook Express . You can use Outlook if you have Microsoft Office . You can also use Windows Mail . Thunderbird from Mozilla also works fine under W 7 .
Best regards .
fanaudi .
Feb 20, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How to download outlook express to send mails
You can't really download Outlook Express as it is part of Windows XP.
If it is not there, you can add it though the Add/Remove Programs option in the Control Panel. Select the Windows Components icon in the left-hand pane.
In Vista Outlook Express is replaced by Windows Mail, and in Windows 7 there is no email program, but you can download Windows Live Mail.
Oct 05, 2010 | Computers & Internet
Need printer driver for windows 7
Hi, David. I had the same problem, and there is a solution. There isn't a driver for Windows 7, but under Windows 7 you can install a virtual machine, that runs a fully licensed copy of XP on your machine. You can download this from Microsoft. Once you have installed a virtual XP machine (and it's not hard at all to do - maybe 10 minutes), you can load the DYMO software and drivers for XP, and your LabelWriter EL60 will work just fine.
Regards,
- Jim
Dec 16, 2009 | Dymo LabelWriter EL60 Thermal Printer
Computers & Internet Logo
112 people viewed this question
Top Arts & Letters Computers & Internet Experts
David Payne
David Payne
Are you an Arts & Letters Computer and Internet Expert? Answer questions, earn points and help others
