Question about Plumbing
I have an artisian well and all winter the pressure drops. The pump turns on and off all day and night. I noticed water leaking outside the top of the casing. I noticed it 1st when I saw ice on the side of the casing.I have no leaks anywhere in the house or outside. I really don't know what's happening here.
  • 5 more comments
  • David Myers Mar 30, 2011
    Still hoping someone could help me here. I don't know what I should do. Could it be the pressure tank in the house causing the pressure to drop? Help please!
    Thanks, I just got home from work. It is a submersible pump. So a check valve can be put in the house where the water enters the house? I was thinking maybe the plastic line that goes from the house down into the well might be cracked.
  • David Myers Mar 31, 2011
    I've been doing some reading on foot valves. Explains wells pretty good. I don't ever get air in the lines and never have lost prime. Seems like because the pump runs so much my water smells bad now. I know my well has very high iron content. When I 1st moved in I would water the grass & flower beds. Didn't think much of the water hitting the house till my whole bottom half of house turned brown. Been here 5 yrs and this is the 1st sign of any trouble. House & well about 13yrs old. Are the new well pumps any more efficient than the old? Just trying to cut the elect bill some. Even bofore this new problem.
    Ok, i'll have to get a check valve and install one. Probably won't be able to till the weekend because of working. Thank you!
    I was just checking mine. There is only about 4 inches of plastic pipe coming through the basement wall then a gate valve to it. Then after that the rest of the galvanized piped system. Really no room for a check valve. Looks like I'll be doing some extensive re-plumbing to make room for one. I turned off the gate valve from the well and the pressure stopped dropping.
    Do you think I could just make the 1 1/4" pipe coming out of the pressure tank longer and put it there instead of messing with the plastic well pipe? That might be a little easier, except everything is so short and compacted in. Guess the plumber didn't want it to take up too much space.
  • David Myers Apr 01, 2011
    How do I accept your solution? I do want you to have the credit for it. This is my 1st time on here doing this.
    Our Support Team is happy to answer questions regarding FixYa's website and services. Simply submit the form below.
    For technical problems regarding your products, please post your question to the FixYa community.
    If you're interested in answering questions and becoming an expert on FixYa, click here.
    Email address Your Name Nick I am a ---- choose ---- Regular user/expert Premium user Premium expert Topic Please select a topic Login/Password Issue Technical Problem on FixYa.com Suggestion/Feedback Other Topic Please select a topic Login/Password Issue Technical Problem on FixYa.com Refund/Cancellation Request Suggestion/Feedback Other Topic Please select a topic Login/Password Issue Expert Earnings Inquiry Premium Expert Approval Technical Problem on FixYa.com Suggestion/Feedback Other Other Please select a topic Media/Press Advertising Investor Relations Other
    Type your message here Heatman101 has helped me and I want to accept his solution. There is no box to do that. I really want him to get the credit for this. I wasn't aware there was a certain time limit on accepting. Can ou make sure he gets the credit please?
  • 1,514 Answers
Most water pumps which pump water from a well into a house have a pressure vessel which keeps the water pressure up without the pump running constantly. When the pressure in the pressre vessel drops below a certain level the pump comes on and when it reaches a certain level it turns off. When there's no taps/faucets running the pressure should stay constant. To prevent the water just returning to the well there has to be a non return valve. It's possible that the non return valve is leaking water back to the well. This would account for the pump running night and day. As the water is just returning to the well there would be no sign of leaks.
The fact that you saw ice on the casing could mean that there's a leak elsewhere, the most likely places being either a pinhole in the pressure vessel or a joint. However if these were leaking there would be water to be seen. A pinhole in the pressure vessel would result in a fine jet of water spraying from it while a leaking joint would have a constant, but possibly very slow, drip. If you feel around the joints you should find one of them wet if this is the problem.
The pressure vessel has a bladder, like a football bladder, which should contain an air pressure of approx 20Lbs. Over time this drops and it should be checked and pumped up, if necessary, once every year. There should be a valve, like on a car wheel, for pumping it. It's usually covered with a black rubber dirt cover which can be pulled off to pump it and pushes back on afterwards. To pump this you need to turn off the electric power to the pump and run a tap/faucet until the water stops flowing. Leave the tap turned on while you pump the pressure vessel so that the water can escape and not give you a false pressure reading. You can use a car pump to pump it up. When it reaches 20 lbs you can turn the power back on and turn off the tap. If this pressure drops too low the pump will continue to work but will run almost constantly as it will not be able to hold pressure. When it's pumped up you'll notice that the pump only comes on when the water pressure in the vessel drops.
I hope this is of some value in solving your problem.
Posted on Apr 01, 2011
    President:
  • 2,468 Answers
First,!!!, how deep is this well 600 feet or lower??? & what is the (Vacuum/Pull to the up-bound intake gauge to the pump intake) & outbound from this wells pump(& what pressures are there, possibly, are you getting sand into the intake of the pump(from the pump at the base) from the terrain and starving the pump??? Also, is it a Jet or Deep-well unit???
  • 12,061 Answers
Ok as the moisture turns to Ice and freezes it expands and so do any joins holes or gaps these may or may not close up, when it warms up? if they don't then there is a gap water may come out. The same thing may apply to the water in the ground, , at the surface or close to, the colder water is sort of thicker, harder to move and therefore less pressure would be exerted from under the ground, and less water would come out in colder temperatures? due to atmospheric pressures?
There should be glands, "O" rings, Gaskets, around the mating pieces of the pump, perhaps these should be checked? perhaps at the colder temperatures they don't seal as well, and one is losing pressure?
Also maybe the power energy drops over winter, perhaps the power is browned out, and the pump doesn't get the power to work at full capacity, that it may perform in say the Summer?
It may pay to remove the pump and give it a complete overhaul, and service.
It's all just a theory?
Posted on Mar 31, 2011
  • 43,501 Answers
You did not say if your pump is above the ground or in the well...
Either way it sounds like the problem is with the foot valve or check valve that keeps the water from going back into the well...
If it is a submersible pump then you can install a check valve by the pressure tank to keep the water from flowing back into the well and out through the pump...
If you have a jet pump on top then a check vlave can be much more difficult and it is probably better to pull the piping in the well and replace the foot valve...
heatman101
Posted on Mar 30, 2011
  • 5 more comments
  • D. Floyd Kolb
    D. Floyd Kolb Mar 30, 2011
    Did you get my comment back to you??
    There is a check valve that is bad and that is what is allowing the pressure to drop by allowing the water to flow back into the well...
    heatman101
  • D. Floyd Kolb
    Comment back to me as to what type of pump you have and I will then be able to give you more info about how to fix it...
  • D. Floyd Kolb
    D. Floyd Kolb Mar 31, 2011
    Yes, a check valve can be placed in the line before the tank...I don't think the pipe is cracked or the pump would just run and not build pressure and shut off...
    This on/off thing will also stir up the water and can make it smell bad...also...
    The efficiency of a new pump would be just a bit better, but not enough to justify replacing the old pump if it still is working...
  • D. Floyd Kolb
    make sure to do it as soon as possible as what is happening is very hard on your pump...
  • D. Floyd Kolb
    Also, because you did not accept my answer the question went back in the list because I did not respond in 4 hours...please if I have helped you make sure to accept my answer so that I get the credit for it.. Thanks!!
  • D. Floyd Kolb
    Yes... you can place it there by the tank...
    It does not matter where you have it as long as it interrupts the flow of the water back into the well...
    The turning off of the valve confirms what I thought...the water is running back through the pump...
  • D. Floyd Kolb
    D. Floyd Kolb Apr 01, 2011
    Honestly I do not know as I am never on your side of the screen..:-) I will however forward this to the community manager and they will make sure it happens...
    Thanks!! for using Fixya!!! I hope that you still will view this as an overall positive experience.
    You have a very fine day!! I'm glad that we did get your problem solved!!
    heatman101
How can I tell if pressure pump is bad or if I have water leak.
pump is producing pressure so it is ok
loosing pressure indicate pipes leaking or non return valve leaking
Feb 21, 2018 | Amtrol WX-203 WX-203 146S30, 32 Gal...
I keep losing water from the radiator feeder bottle.i have to top it up even on short journeys. what may be causing this problem
Check dipstick for cream like sludge=water in oil. Check tailpipe for white smoke = water into combustion chamber. If yes to any, leaking head gasket or cracked head. You can also get a radiator test pump from most loan-a-tool programs at parts stores. Pump up pressure and try to find leak as pressure drops. Seeping hose or small waterpump leaks can be hard to notice if they only happen while driving. Even bad radiator cap can do this.
Jun 24, 2015 | Cars & Trucks
My current water tank was installed 12 years ago With Bladder. 1 hp motor. 80 gals. Water Pressure is consistantly low. When reset to 40-50 lbs, it drops shortly after back to thirty lbs in the house....
If I understand you, this is a water well. For pressure to drop, water must be going somewhere. If you see no leak in the tank, that is not the problem.
Check all outlets, faucets, toilets, showers, outside faucets, etc. If you see no leaks and the pressure is still dropping, there is a check valve either before the pump or in the well and this could be leaking back. Either way, the pressure should drop to zero unless the pump comes back on.
Gary
Jan 25, 2011 | Wel - Bilt Electric Portable Air...
Hello, Our Flotec Shallow well Jet is installed in our basement a distance ( perhaps 50 feet or so from the well casing outside in the yard. The pump was installed as a replacement for a worn jet pump...
Hi, Tom, W/D here.
You shouldn't really need a check valve as the foot valve is in effect a check valve.
Next time that you are near the pump when it kicks on and you are using no water, let it achieve full pressure and kick off. Close the discharge valve, isolating the pump and suction line. Watch the pressure gauge. If the pressure falls, you either have a leak in the suction line, possibly a leak at the well head (sucking air), a leak in the casing riser pipe or bad foot valve.
If the pressure holds steady, open the discharge valve and note the pressure. If it falls immediately upon opening the valve, the leak would be on the house side if the pump. Look then for any sources of water usage (ice maker, drips in the tub, water from the pop-off valve at the water heater, etc.).
Best regards, and good luck.
If I can be of any further assistance, please post back.
--W/D--
Jan 22, 2011 | Flotec Corrosion Resistant Shallow Well...
My check engine comes on when its cold or damp outside and now since its winter i have noticed coolant leak around water pump. does my water pupm need changing and could that be why my engine light was...
There are litterally hundreds of reasons why your Check Engine Light could becoming on. The only way to find out is by having your engine computer scanned for fault codes. If your water pump is leaking it needs to be replaced regardless of whether or not it is the reason for the check engine light coming on. I don't know the labor rates where you are...come to think of it, I have no clue where you are...But what I can tell you is that the water pump on your car is not very expensive at all compared to most of the water pumps I change. It's one of te easiest water pumps out there...not much labor involved.
Jan 22, 2011 | 1995 Buick LeSabre
The pressure tank psi may be too high. To set it you get the system to pressure up and stop then check that water pressure. Whatever that is, is what the tank should be set at. Too much air pressure and the water pressure will suddenly drop before the pump kicks in.
To set the tank properly turn off the pump, drain all water pressure, then set the air pressure in the tank to the same as the water pressure was. Turn it back on and check again.
Apr 14, 2017 | Water Heaters
Combi boiler loosing water pressure in heating system no visible leaks i have heating pipes under a concreat floor carpets not damp and no con- densation on my windows the pressure drop is over...
There is a 15mm pipe from the pressure relief valve which should so through to the outside. These valves are prone to leak after time. Look at the end [outside] of this pipe. Wet = leak from valve
Dec 20, 2009 | Water Heaters
I have noticed a couple of drops of anti freeze on the floor the last couple of days the bottom of the car is starting to get wet with antifreeze
Right above the water pump there's a 90 degree elbow that's made out of plastic that comes out of the intake and goes to a heater core hose. That's where mine was leaking. Get it replaced soon because it will get worse. I heard this is common on these 3.8L engine.
Nov 09, 2009 | 2004 Pontiac Grand Prix
I have a 2001 saturn wagon, Coolant leak where the alternator is!
What may assist in your diagnostic is a system pressure tester.This has a hand pump to where you can pressure up the system to 12 to 17 lbs and this really helps bring on hard to find leaks. You may be overlooking coolant leaking from the "weep hole" in the bottom of the water pump or a place that might become much more obvious inspecting this system under pressure. The tester also helps diagnostic by noticing if the system holds pressure for a sustained amount of time.A small leak will drop your 12 psi in a matter of a few minutes and you will continually need to pump a few more times to keep that pressure which further indicates the system is leaking down.
Aug 26, 2009 | 2001 Saturn SC
Vaillant boiler (VCW GB 221) not heating up water or heating although the pilot is lit. Pump is heard working okay but there is small drips of water underneath boiler. Any idea's?
The movement of the diverter valve is critical on this appliance, and is located on rear right of the boiler, when hot water is turned on, theres are two microswitches, which must break (they both close in Central heating mode), if pump is running, it is recognising the hot water demand, check microswitches are breaking, if not, it tends to be a defective servo valve (located above the water valve), or a blocked/ restricted control line (small copper tubes which connect into the servo valve)
Nov 29, 2008 | Heating & Cooling
Plumbing Logo
418 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
