Question about Peg Perego John Deere Gator HPX
Need help and step fixing the front end on a john deere gator
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Are you referring to the childrens toy?
Posted on Jun 08, 2012
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Posted on Mar 20, 2009
  • 156 Answers
SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
Need john deere 825i repair manual
Obtain the repair manual by ordering directly from John Deere.
Apr 19, 2018 | John Deere Garden
Is there a hand brake adjustment on a 855D
John Deere Gator XUV 4x4 855D adjusting handbrake ...
www.fixya.com/.../adjusting_handbrake/.../john_deere/gator_xuv_4x4_85...
John Deere Gator XUV 4x4 855D atvs adjusting handbrake unsolved issues. Ask your John Deere Gator XUV 4x4 855D questions. Get free help from atv ...
  1. John Deere Brake Adjustment‎
    Adfixya.com/John+Deere+Brake+Adjustment‎Troubleshooting Tips
  2. Free Manuals
  3. Instant Solutions
  4. Instant Answers
  5. John Deere Brake Adjustment‎
Jan 17, 2016 | John Deere 2012 Gator XUV 4x4 855D
you probably have a disconnected motor, follow the steps below and check the motors to make sure they are connected
1. remove the red pin at the front of the dump bed
2. remove the two black pins at the rear of the dump bed
3. remove the dump bed
4. lift the green plastic cover off
Oct 19, 2012 | Peg Perego John Deere Gator HPX Ride on...
Where is the battery located at on the john deere gator hpx?
the battery is behind the front bumper. There are tabs on either side in wheel wells to release the front end panel and it pivots downward to access the battery compartment.
good luck!
Dec 27, 2010 | Peg Perego John Deere Gator HPX Ride on...
Where is the battary? Peg Perego John Deere Gator HPX 12 Volt Ride on Toy
the battery is behind the front bumper. There are tabs on either side in wheel wells to release the front end panel and it pivots downward to access the battery compartment. good luck!
Dec 22, 2010 | Peg Perego John Deere Gator HPX Ride on...
My sons peg perego john deere jeep only sets off in second gear what will fix this fault
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
Jun 04, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Logo
42 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
