I've recently installed my black ink cartridge and nothing happens when I try to print out. I've removed the sticker and checked all troubleshooting problems, and when I try to print, it comes out blank. The cartridge is in correctly, and I've checked my USB cable, nothing seems to help.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
As this is a printer problem as opposed to a PC problem, we are in need of additional information. Please provide info regarding the printer model as well as the PC. Was this a routine cartridge change, and have you done it before with no negative consequence? Is the printer new or how old is it, and how old is the cartridge?
As you indicate black cartridge, it sounds as though this is a color printer. Have you tried to print a color document? Go to your printer settings and make sure it is set to print in color; then choose some color page (even this web page) and attempt to print it. If the color prints and the black doesn't, it is a bad cartridge.
It is also interesting that you mention the USB cable being attached. Do you have reason to believe the PC and printer are not communicating? If so, go to the Control Panel (Windows) and check your Printers to see if the printer is listed there. Check all the windows for status and any indication of an issue. If it is not listed, there could be a problem with either the cable, the USB port, or an intermediate piece of software.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, as well as responding to the questions posed above, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
Posted on Aug 03, 2008
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
Hello! We have a Brother MFC-J615 printer & we have been having a problem recently with the Black ink. It just randomly started to not print any black ink, but the other colors are just fine. The ink...
It sounds like you're not using the correct ink for the printer.
Each printer requires a different formula and thickness of ink for it to work correctly.
Have you recently started using a new bottle or topped up with a different ink in the system?.
Jun 29, 2011 | Brother Office Equipment & Supplies
My TX550W ran out of Black Ink (T103) and I replaced it with a Genuine Epson Cartridge compatible with my printer (73N), My computer status monitor/ink check on the printer shows the black ink is now full...
Sometimes the ink does take a while to come from the cartridge to the print head. Performing 1 head cleaning procedure may fix this. But only do this once, anything after is just wasting ink. Also make sure no part of the air tab sticker has blocked the air hole in the cartridge. Have a look at the new one you have to find the hole. Its just under the sticker you take off before installing it into the printer.
I hope this helps Regards GM
Apr 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
Dell V305w Printer Alignment problem. Remove tape from cartridges or check troubleshooting. Press > to continue. Ink cartridges reset, tape removed, trays aligned. HELP!
In my case this happened with black cartridge out of ink, colour cartridge low; replaced black: had permanent alignment problem, though test print looked OK; wouldn't print black. Replaced colour cartridge, then it all worked OK, straightaway!
Aug 24, 2010 | Office Equipment & Supplies
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Power Light Continues to blink.
if you are having issues after installing the new cartridges , then perform the following steps.
unplug the power adapter and remove both the cartridges and then power on the printer , look for the power light. if it does not blink then .
install the black cartridge first and then try to print , if it prints fine its ok. then remove the black cartridge and then put the color one in and then try printing or copying .
if it doesnot print with any either black/ color then you have to replace that particular caratridge..
lemme know once u r done....
May 02, 2008 | Lexmark X1270 All-In-One InkJet Printer
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Error message ?incorrect black cartridge?
You can get this message even when the cartridge is the right one, but the joints are covered in ink. Try the following solution- fill a bowl with hot water (not boiling hot), 3 mm high, remove the cartridge and place it so only the joints are submerged in the water, for a minute or 2. Dry it well, clean the joints again and place it in the printer. Good luck.
Feb 22, 2006 | HP PSC 1110 All-In-One Thermal Printer
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
