Question about GE WBSR3140DW Top Load Washer
The washer is powering up but the motor is not spinning as strong as it should it is moving back and forth but very slowly, water is filling up and draining but the cloths is still wet and did not wash, because the motor is not spinning.
  • Sean Miller Mar 26, 2011
    Hi my name is Sean, how old is the washer?
    Thanks
  • 27 Answers
Sounds like you may need a motor. If the electronic brake fails it will cause the washer to slow down. there is a led on the board in the motor. See if you can find it and count the number of flashes. 9 flashes is bad brake.
Posted on Mar 26, 2011
Drum willnot move on start.it just thumps
If the washer won't agitate the stator assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Sep 28, 2014 | LG WM2487H Front Load Washer
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
Why wont my washer agitate
must be worn out dogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a Maytag Neptune FAV6800AWQ Serial Number
Fireman,
Excellent info wish all post would start off like this. The first two digits of the s/n are your series number a Series 16 machine I’m an owner no expert and will try to help.
I assume you have the Service Manual but just in case.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
“”I can grab the drive belt and effortlessly move it back and forth-pulley spins and motor spins--Should it move like this?””
There should be slight resistance.
With the front cover off and be careful of the rotating drive belt can you start a Spin Only cycle?
Do you see the Motor rotate the Clutch Pulley assembly CCW? If so the wash basket should spin CCW just raise the washer top and verify the CCW/Spin rotation.
If that works again with the front cover off start a Quick Wash cycle min Soil/Spin settings and observe as the washer. As it fills the wash basket will be rotating CCW don’t raise the washer top to high or you will spray water around.
After the water fill the washer will start to Wash/Agitate. The Motor will rotate the Clutch Pulley CW and the Tumblers will rotate. Do you see this action.
You can go into Service Mode with this procedure and dump the wash water if the cycle fails with this procedure.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
Thank you again for the Model number and Serial number…. other readers this is how you post an issue.
Waiting for your feedback………Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer aggitates poorly when it is loaded
Check belt tension. Motor capacitors weak. Check the spin mode. Finally check the motor.
Apr 03, 2010 | Washing Machines
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
GE WBSR3140DW Top Load Washer Logo
50 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
