Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
I own a hoover steam vac model # F5915900 inside the recovery tank the seal broke. Where can I buy a new rubber seal?
  • 710 Answers
Here is the webpage for vac parts warehouse. This shows a diagram of your steam vac. You pick the part and buy it.
Hope this helps.
Handie Andie
Posted on Mar 26, 2011
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My steamvac wont pick up the water. it is spinning and blowing out the water, but it wont **** it back in
The most common reason for lack of pick-up is that the lid is not seated firmly on the recovery tank. Lack of pick up is always caused by an air leak. A less common possibility is that the large round rubber seal that the recovery tank sits on has fallen out of place. If you look at the bottom of the tank, you will see a round hole. When you install the tank, this hole sits on top of a rubber seal on the motor shell. Be sure the seal is in place.
Feb 05, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac has no suction, blowing air from middle of bottom
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Make sure the tank lid is aligned to the recovery tank to seal, and assure the square panel is in place on the front of the recovery tank that connects the vacuum of the tank to the clear nozzle plate.
Mar 22, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac doesn't pick up all cleaning soluation when cleaning carpet? I have clean both filters
Please look to make sure the rubber ring gasket is still in place under the recovery tank. The tube on the bottom of the recovery tank must seal to the rubber ring to get suction.
Dec 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
My steam vac doesn't seem to have suction. Help?
(1) Make sure tank lid is sealed to the tank.
(2) Is the filler panel in place on the front of the recovery tank? (Square shaped plastic panel)
(3) Is the tank gasket in place under the hood? There must be a rubber gasket on the round pipe that the recovery tank seals to when it sets down in to the cleaner foot. This connects the vacuum path to the tank.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam cleaner will not pick up the water the machine pu
Two checks:
(1) Is the lid aligned and sealed to the recovery tank
(2) Is the round rubber gasket installed on the tubular post under the hood, where the tank seals to the base? The tube extending down from the tank must sit on the rubber seal to get vacuum from the motor.
Sep 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Trouble installing tank seal on aHoover
Put a little silicone spray on it.
Regards, W/D
Jul 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking Solution Tank/Seal Install - Hoover Steam Vac
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Nov 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
462 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
