My laptop seemed to be frozen then it shut off by itself. I tried turning it back on and it sounded like it was booting but the screen stayed black and then the caps lock and scroll just blinked mulitple times
  • 37 Answers
It seems related to hardware. Remove external devices and try again. If not booting then service is probably required. You can try re-seating the memory and try again, you will see panels at the bottom of the unit. The one for the memory is usually the one in the center of the whole unit. This video will show you to remove and reposition memory
http://www.youtube.com/watch?v=D1oTz-F6xME&feature=related
Posted on Mar 26, 2011
  • JPHH Mar 26, 2011
    Remember to disconnect power sources and touch a metal surface to discharge static before removing the memory.
MSI L1600 netbook seems to be stuck in sleep mode. The power also cannot be turned off - even removing the battery and replacing it.
try to boot the computer, if you hear the start up sound then mobo is not bad. this issue could be caused due to boot sector viruses as well. see if the back light turns on ..
check the settings in bios and try to run a recovery. if neither helps
call 1-877-805-1027 for expert help
Jul 30, 2015 | MSI Computers & Internet
Toshiba Satellite not Booting (No post Screen)
you can't boot on safe mode under F8 function key?
Mar 30, 2014 | Computers & Internet
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
In the middle of a session the screen turn black, but the computer seem to be on... we need to stop it with the middle button and restart it again. Usualy it start back normaly again. But one time, instead...
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
Jan 13, 2011 | Acer Aspire 4520-5582 Notebook
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
MY LAPTOP WENT BLACK AFTER I SPILLED SOMETHING ON
Its better to show it to technician bcz it seems the motherboard inside lost bios flash and its unable to detect old settings so that everytime it reboots checks bios and then reboots again to flash it. Better show it to a local technician. One other way is to try booting it in safe mode and then check if it works.
Oct 29, 2009 | Compaq Presario Notebook
Screen going blank and laptop freezes.
One thing that I've noticed about the Inspiron 1000, is the LCD ground is done exclusively thru the hinges. Try tightening the LCD hinge screws (Marked with a (D)) 2 on the bottom of the chassis and possibly 2 on the back. (I just tightned every screw I could find)
Once the ground connection is improved, the LCD may work better
May 23, 2009 | Dell Computers & Internet
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Laptop Wont Boot Up
In that situation, try to boot it in SAFE MODE. You get into this by pressing F8 during boot up. The menu will come up and you choose the mode you want. While in safe mode you will have to try and use system restore to go back to when the computer was working. It's like PC time travel.
Dec 05, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
