Question about Honda 3000 Watt Portable Generator
I have had this Honda 3000si Gen for more then 5 years. i ran it for 2 days and let it set. Now it will not start? How can get it started.
    Scholar:
  • 143 Answers
Sounds like your carburator might be dirty there are a couple of pin sized holes that can easily become clogged in the carb if you work on them take apart the carb and get some carb cleaner . you will be suprized to see the crud that will collect in the bowl . I go to homedepoe or lowes to the welding section and get a torch tip cleaner its like 3 or 4 bucks it has some tiny wires with ridges on it that will clean out the holes on it .Your carb might have several types of plugs or methods of securing the bowl to the carb some have a bolt with a screw in the middle some just a bolt some have a spring clip . if it is a bolt with a screw in the middle you can remove it and catch the gas as it drains out once empty remove the bolt to release the bowl there i a gascket on the top rim of the bowl remove any debree from the bowl and spray carb cleaner there is prob a yellow residue from the gas that is the oxyidation gas oxyidizes after thirty days .if the nut you took out has two holes in it use th tip cleaner to clean out the hole then look at the float it hinges on a pin that pushes up a little triangular pin that pin has a rubber tip on it it controlles the flow of gas into the bowl if any of the parts are fowled up to bad or rusted go to a lawn repair shop and get a carb kit for your motor get all info off tag or cant get the right parts with all the emissions on the carbs each one is different.once cleaned out put back together if it still runs funny there is another part that comes off the side of the carb it should be a coveer with 4 screws holding it in place on the inside there is a gasket with a spring on it the spring has an aluminum cover to keep from tearing the gasket up replace it with a new one the little flap on the other end act like valves close all back up thenthe screw in the bottom of the carb should be screwed all the way in then un screw 2 1/2 turns and it should be set to about the right flow adjust in or out if it isnt right hopes this helps if you need more help on this leave feed back love to help
Posted on Apr 02, 2011
I HAVE A HONDA 2005 HONDA SHADOW AERO. RAN FINE YESTER DAY. WENT TO START IT THIS MORNING AND FORGOT TO PULL OUT CHOKE IT STARTED THEN DIED. PULLED THE CHOKE STARTED UP AND RAN FOR 45 SECONDS AND THEN...
You have 2 solutions : take out the spark plugs and dry them with cloth, put them back in and start the bike.
Or, leave the bike over the night and the excess fuel on spark plugs will evaporate.
If the engine is hot and you have this problem, just leave the bike for half an hour and start it.
Sep 29, 2013 | Honda VT 750 Shadow Aero Motorcycles
Car won't start until jumped
Most likely the battery. Most auto parts stores will check it for free with the hopes that you will buy your replacement from them.
Jan 01, 2012 | 2002 Honda Odyssey
Honda EU3000is. 2 year old unit used by electric start at least 5 days a week. My gen has recently stopped staring by the electric start, it turns over but just not as strong as when new, what i mean by...
I have a 5 year old EU300is that would not start with or without the battery. I went through all the usual such as gas, plug, oil, etc. The battery showed 12 volts, however, when tested further it would not hold a load. I bought a new American made battery and now the unit runs fine.
Jan 29, 2011 | Honda 6370C - Parallel Power Kit For ...
1996 5 speed honda accord. sat for a year. put in new battery. everything lights up, but car wont start. never had previous problem.
Are you saying the car turns over (cranks) but it does not start? Or, the car is Not turning over?
If it is cranking over but not starting, and it ran fine before sitting for the year, it may be water/moisture in the gas. Try some dry gas, and/or Carb-fuel injection cleaner in your gas tank.
Jul 12, 2009 | 1996 Honda Accord
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Oct 24, 2008 | 1994 Pontiac Bonneville
1993 Honda Accord Timing belt
Tell us who made that belt so we can stay away from them.
Aug 06, 2008 | 1993 Honda Accord
Honda 3000 Watt  Portable Generator Logo
136 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
