Question about MTD Genuine Factory Parts Tractor PTO Belt
I have a Craftsman LT1500 427.288810 and the PTO belt broke. When I try to install the new one, it does not fit between the driven sheeve and the side frame. I think I need to take that pulley off, but I can't get to it. This seems like a lot of trouble to change a belt. Am I missing something?
    President:
  • 3,074 Answers
Here is a website that will walk you right through the process, Good Luck Tim;
http://www.ehow.com/how_5151371_replace-belt-craftsman-riding-mowers.html
Posted on Mar 25, 2011
How do I replace the Blade Clutch Assembly on a Craftsman mower, model 817.288160?
There is one bolt in center of pto clutch. Its best to have an impact to remove this. If you try to remove with a wrench engine will spin. Remove both belts first. Then simply unplug the PTO, Use impact wrench and remove center bolt and gently pry off. Installation is the reverse order.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Oct 15, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mower stalls
make sure belts arent around the guides to keep the belts on.
does it smoke or make any other noise
why did yu change all the parts
Jul 09, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Pto on yardman 42 lnch cut belt will not go tight
A spring keeps the tension on a PTO belt. It may be broke or unhooked.
Jan 13, 2013 | Craftsman Garden
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when...
try removing the belt and try to spin the blades by hand. are they stiff to turn? if yes try to oil the bearing assys up under there and spin em again. if that seems to work out put the belt back on and mow away again! seen this on a neighbors rider a few times
Nov 06, 2017 | John Deere Garden
Blades will not engage, belt not broke but is very old, do I need new one?
Check if the belt is loose. With the engine off, try to pull the mower deck belt around by hand. If you can pull it easily, and the blades don't turn, then replace the belt. If it's hard to pull, and you can see the blades try to turn as you pull it, then your problem probably isn't the belt, but the PTO clutch or mower engage switch.
Jun 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a Craftsman 26 hp, 48" mower...mower starts runs but when I try to engage the blades nothing happens. Checked all the belts, ck for blockage but nothing...what would the next step be?? Tks
When you say nothing happens...is the PTO engaging? You said that you already checked the belts...if none of these are off...you maybe looking at a new PTO clutch.www.nnyparts.com
May 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Apr 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD Genuine Factory Parts Tractor PTO Belt Logo
432 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
