I have a Quest QSR5000 Receiver, not under waranty, the main left channel does not work. Everything else works, all other channels, but there is no main left stereo channel. What could I do to attempt fixing it myself? Thanks
Fixed mine soldered main pcb all discolored joints. mine was doing all kinds of random stuff, now works fine. just be careful not to bridge connections and do not overheat components. just heat joint long enough to make a good joint.
Posted on Oct 22, 2012
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Left channel out
probably I would say no. Unless you know how to read a schematic or know how to do certain small static checks on the output devices and the drivers as well as the power suppy feeding these devices.
Posted on Apr 05, 2006
  • 15 Answers
SOURCE: Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Posted on May 11, 2007
lynchms
  • 93 Answers
SOURCE: 5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Posted on Feb 22, 2009
  • 4234 Answers
SOURCE: I have a Fisher RS-717 stereo receiver, amplifier.
Yes you can use either A or B without a problem. The restriction is when you have both A & B connected. In that case, the speakers MUST be a minimum of 8 Ohm impedence. Using either A or B, you can use speakers of 4 Ohms impedence.
Dan
Posted on Nov 24, 2009
Testimonial: "Prompt answering, appreciate it very much."
My 787 receiver is 10 years old. It worked excellent all these years . It developed distorted sound in the front left channel. I swapped speakers and confirmed that the problem is with the receiver front...
The problem will be in the power amp for the the left channel. One you have identified this on the circuit board you can compare the channel with the right. As they are both the same. Start with a visual check. If anything looks odd compared with the the right replace it. Distortions are often caused by a burned resistor. Though the main power transistors or IC can cause it too. If you can't find anything visual I would replace the main output device(s) for the left channel.
Nov 21, 2017 | Audio Players & Recorders
One channel out on the HK AVR85. Tested all inputs. Is there a fuse inside???
In an answer to to your "quest.... Is there a fuse for speaker output"
• the answer is none.
but there is a relay in between the main amp output
and the speaker terminal at the back.
In your statements : " Inputs all good ",
• Check first the line outputs at the back of the receiver , just to
determine if the preamps are working.
• connect outputs to a separate amplifier
the answer will determine
your "quest ...is this most likely a bigger issue??? ? "
I almost forgot to ask what channel are you referring to?
Say, front left channel like you said is dead,
after checking the line out there is no output either, then the
trouble or fault can be starting from the input line to these output.
These could be capacitor coupling, resistors , op-amp IC
or possibly just a cold solder joints.
Here is a sample troubleshooting :
only for Computer Speakers
(but may also apply)
• If there is an output , then trace on the main left amplifier
could be a colder joint also, check until you reach the relay.
Let us know if you have any more questions or if you need
further assistance!
Sep 19, 2012 | Harman Kardon AVR 85
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
RX-V1 (No left main channel sound)
Sounds like the output stage of the amp is bad. Needs service.
Charlie
Aug 24, 2009 | Yamaha RX-V1 Receiver
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
How to connect bose 901 speakers to 5.1 setup?
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Sep 09, 2008 | Bose 901 VI Main / Stereo Speaker
Sound only comes out of left channel, only dvd player works
I would Initialize Unit back to factory settings by turning off main power switch then hold both 6.1/7.1 surround and direct buttons ( they are next to each other near main power switch) in while turning un main power switch. Hold both buttons until you see all lights light up. Then check functions and setup like you bought it new.
Owners manual also explains how to initialize receiver
Feb 09, 2008 | Denon AVR-4800 Receiver
Remote canot find receiver
My guess is that the pulse length or the number of pulses used by QUEST is different from what most remotes use. Call QUEST and you will likely find the answer GOOD LUCK!
Jan 07, 2006 | Samsung SAM1100 LCD Remote Control
91 people viewed this question
 Grubhead
Grubhead
