Question about Kitchen Ranges
Oral-B ProfessionalCare SmartSeries 4000 rechargeable electric toothbrush battery is still good, but it make hum noise and not turn, i try to turn inside plastic gear, look like it jammed.
    Problem Solver:
My husband has one & his hums too......i just figured thats what they do
Posted on Sep 21, 2011
What are the best electric toothbrushes available?
The best electric toothbrushes are the Oral-b Professional Care and the Phillip Sonicare Diamond Clean. You can find more information on these electric toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
Feb 04, 2013 | Health & Beauty
What are the different types of toothbrushes?
There are three types of toothbrushes that are commonly used:
  1. 1. Manual toothbrush
  2. 2. Rechargeable electric toothbrush
  3. 3. Battery power toothbrush
For more detailed information on these toothbrushes, check out Oral-B website
Jan 10, 2013 | Health & Beauty
Lost instructions for use of oral b dual head vitality toothbrush
If you mean the Vitality Dual Clean toothbrush, you may download the manual here.
Dec 30, 2011 | Oral B Vitality Dual Clean Rechargeable...
How do I set the time on the Oral B "Smart Guide". I have lost the instructions leaflet and I have to change batteries and reset the time.
Source:
http://s.cdon.com/media-dynamic/files//40/15561540/braun-oral-b-professionalcare-5000-triumph-manual.pdf
A flashing 12:00 indicates that you can now adjust
the clock time.
Press and hold the set button until 12h is
displayed. By briefly pressing the h/min button,
you can toggle between 12h or 24h daytime
format. Push set to confirm your choice. Then
the hour digit starts flashing. Press the h/min
button until the right hour appears and confirm with
set. Proceed same way to set both minute digits
(picture B, page 4). If you prefer not using the clock
feature, the flashing 12:00 will disappear automatically after 24h.
Conclusion...mine is defective, the set button must be broken.
Jun 28, 2011 | Oral B PC5000 Toothbrush, Professional...
My 5000 series tooth brush will not charge i tried it with a few adapters and still no result could it be the base or plug that is malfuntioning , i am an electrician and there is power in the socket so...
I have bought many rechargeable devices and about 4-5% of them have bad Chinese batteries in them. I also have converted nearly all battery operated items to rechargeables and these often have spotty performance with several out of a couple of dozen not worth keeping. You might try running the batteries down as far as possible and then trying to recharge. If they are NiCads, they may have developed 'memory,' a known weakness of that type and NiMh batteries in particular seem to need several charge/discharge cycles before they will come somewhat up to their rated capacities.
Mar 24, 2011 | Oral B ??? Oral b Professional Care...
My oral b rechargeable toothbrush (brand new out the box at the weekend) wil not recharge - have thrown the intructions away thinking "what is there to know you stick the toothbrush on the charger...
The plastic connecton has a coil in it, much like how a transformer is done. If you read up on how a transformer works its pretty much the same principle as it works on Induction. There is a coil and core iron in the end of the toothbrush and in the base, this creates AC current which inturn causes induction to flow through the coils and charge the battery. And about the reason why it is not charging is probably down to the battery being flat ( happens even when new ) or there is a loose connection when it was being transported.
Hope this helps.
Mar 22, 2011 | Oral B Vitality Dual Clean Rechargeable...
What is mean this my uterus is normal in size and contour. No filling defect / anomaly is seen
Hi, you are healthy and you have nothing to worry with your uterus based on oral B check.
Jan 17, 2011 | Oral B ??? Oral b Professional Care...
My Braun Oral-B Sonic Complete Toothbrush wont hold a charge
I had the same problem today. I use the charging plug which has the "wrench" remove the bottom screw...I was attempting to remove the battery to reset the brush. I could not get the bottom of the brush off as I did not want to use a screw driver or similar to pry it off in case I needed to return the brush.
So I was trying to pull the bottom off and my finger was on the on/off switch, as I was wiggling the bottom of the brush to try to dislodge the battery it started working.
The brush seems to have a reset button on the back but that did not do anything. The display also has moisture trapped inside it, which I am sure is not good!
Any way try this and maybe the battery will come out and I am sure that will reset the brush...if not maybe you will get lucky as I did and wiggling it will work. BTW, this is with the Oral-B Triumph Professionla Care 9000
Apr 21, 2008 | Computers & Internet
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
