Question about Vizio 42 in. LCD TV
My 42" Vizio TV turns on and says No Signal, then
Push INPUT on remote, select the input source you want, keep changing channel to find a exist channel.
Posted on Mar 25, 2011
SOURCE: 42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
Posted on Jan 11, 2009
nicknovikov
  • 100 Answers
SOURCE: how much do amain board cost on a 42 inch vizio tv
shopjimmy.com.check this site.
Posted on Oct 05, 2009
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
SOURCE: vizio vw42lhdtv10a 42
check out the power supply board! Look for popped capacitors. They either leak or swell up. They are the can shaped things on the board with the plastic coverings on them...you can usually see a swollen cap sticking up over its covering as a telltale sign.
Good luck and be careful
Posted on Mar 16, 2010
SOURCE: UVERSE REMOTE CAN NOT TURN OFF VIZIO 42' TV
The documentation that came with my U-Verse equipment doesn't list Vizio products, but I have been using 1343 which I saw suggested on another website. AT&T's support site has a new code list (http://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf) showing Vizio under the TV section as 1489 and in the HDTV section as 1429, 1433, or 1439.
None of the codes listed for Vizio work with my Vizio LCD(model VO370M), but the 1343 code I've been using successfully is listed in the new list as an LG HDTV code.
Inputs don't work
more likely faulty tuner. have to take it to a repair shop, ask for quote , if the set is old may be cheaper to buy a new one.
Jun 26, 2015 | Vizio SV421XVT 42 in. LCD TV
We purchased a Vizio 42"
This is more of a provider problem. Report the signal problems to the service you subscribe to for tv.
Mar 23, 2011 | Vizio E420VA 42 in. LCD HDTV
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Turn on tv - tv says no signal, then turns itself off . vizio flat panel
i turn on my flat screen lcd television and it just says no signal
Jan 09, 2010 | Vizio VW42LF 42 in. LCD HDTV
My vizio 42" just shut off while watching tv. can this be fixed?
Yes. It sounds it is in the power supply board. Something is breaking down.
Nov 20, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
My vizio 42 in lcd turns off when i press the rgb button on the remote. i am trying to hook up my laptop to the tv
Make sure you have the correct colours matching; R to R, B to B and G to G. I think the blue carries the sync signal. If the tv doesn't get the sync signal from the laptop (the laptop is off or thye cabling is mixed up) it will shut itself off.
I can't be sure if this is the cure but I have 50" vizio plasma which won't stay on if you select and unconnected input.
Aug 19, 2009 | Vizio SV420XV 42 in. LCD TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
2,030 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
