Question about Intermatic Timer 240 Volt 50HZ - For International Use
There are two small wire with round clip inside the timer. I want to know the position for those two wire on my 240 v timew. thank yuo
  • 3,289 Answers
There are dozens of timers made by Intermatic - most look very similar. Please provide the model number of your timer so I can get you the information you need for YOUR timer - not one the "kinda looks like it"
Posted on Mar 25, 2011
  • Steve Mar 30, 2011
    I had hoped you'd reply with your model info - but that hasn't happened. I believe the two small wires you are referring to are those that power the small clock or timing motor. These wires would connect to two terminals that have a constant 240 volts between them - regardless if the switch was on or off. Again, had I known which model you have, I could tell you exactly where they belong.
    It is also very important that this clock be used in places that have a 50Hz frequency - not 60Hz which is common in North America. Attempting to use this timer on a 240V 60Hz system will cause the clock to overheat and lose about 3 hours per day.
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
No power is coming out of the timer. How do I troubleshoot?
GE15207
-Test across terminals 1 and 2 for 120-277 volt depending on power
-Check if any wires are loose
-Check if any terminals appear burned or damaged
-This timer can be wired many many ways, for seveveral different voltages.
-Testing can differ depending on wiring and voltage.
-For 240 Volt ... generally... set timer to ON position... Test across both NO terminals for voltage
-Add comment with image of wiring and specify the voltage
-Links that help identify problem, wiring, and voltage
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
http://waterheatertimer.org/GE-15207-same-wiring.html
http://waterheatertimer.org/images/Fire-inside-timer.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 03, 2015 | Jasco Ge 15207 24-hour Electrical Water...
HOW TO TEST WASHER TIMER MODEL# TAWX700JQ1
sounds like pumps blocked prob a sock or something small like hair clip
Aug 25, 2014 | Estate Washing Machines
How to wire a 240 volt salt water chlorinator to an intermatic 1725c timer
T104 and ET1725 are wired differently since ET series timers have dry switching terminals. Dry terminals receive no power when timer is energized. So ET series timers require jumper wire.
Here is crossover wiring:
http://waterheatertimer.org/images/Crossover-wiring-T104-to-ET1725.jpg
More resources:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html
http://waterheatertimer.org/pdf/Intermatic-et1725c.pdf
Add a comment for more information
May 13, 2013 | Intermatic Hardware & Accessories
Wire a time switch to a pool pump motor
Yes.
240Volt can be turned ON-OFF by cutting power to one of the two 120Volt wires in the 240Volt circuit. You need Neutral wire for 120V, while 240V does not require neutral wire.
http://waterheatertimer.org/See-inside-main-breaker-box.html#120-240
http://waterheatertimer.org/images/T-101-wired-to-control-240-800.jpg
If you have Intermatic 120Volt box timer such as T101 or T103, then 120Volt WH1570 clock motor on back of timer can be changed to 240Volt WG1573.
Other brands timer, it might be possible to change clock motor.
Add comment with brand and model of timer.
If the timer turns OFF power to salt computer, the computer will not operate until power resumes.
Mar 24, 2013 | Hardware & Accessories
Installing the battery can't get the door opened to insert battery
Drawer pulls straight out. Use small screwdriver or metal nail file.
Copy following link for illustration and CR2 battery, and ez-to-follow programming, and wiring options.
http://waterheatertimer.org/images/ST01C-program.html#battery
Remember the drawer is also 'plugged' into the timer, so do not bend small metal prongs on drawer.
This timer comes with 1 year limited warranty against defects in workmanship.
The battery operates timer functions, so once battery is installed, the timer can be programmed before timer is installed in wall.
Be sure to reset timer before programming to eliminate stray code on the memory chip.
Once timer is programmed, the programs remain inside memory chip forever, even with power loss and no battery, until timer is reset of re-programmed.
Reset this timer: Hold down on-off button and momentarily push round reset button with paper clip. Keep holding down on-off until display changes, then release on-off button and begin setting current time and programs.
Nov 27, 2012 | Intermatic & Self-Adjusting Wall Switch...
Amana ALE643RBW Dry will not start. I checked the thermal fuse and the high limit thermostat both read 0 to 4 back to 0 ohms. It was jumping around back and forth. Checked the heating coil it read 10...
Hello Dale,
Having checked the thermal fuseto be good i will give you a partial list other things that could make the dryer not start
start switch
door switch
timer
circuit breaker, use your meter set to volts ac and check for 240 vac at the outlet,if 240 not at power outlet check for burnt connection inside outlet or bad circuit breaker
if 240vac at outlet check for 240 vac at terminal block on back of dryer where cord connects,if 240 at outlet but not terminal block replace cord , if burnt connection at terminal block,replace cord and block
finally the motor,manufactures do not publish wiring diagrams online and the only way for me to tell you to use jumper cord to check motor is find the wiring diagram inside of control panel and place one wire on the terminal indicated as neutral on wiring diagram and one wire on terminal indicated on diagram as run winding
firstly though check door switch to have contunity (0 ohms) and the start switch to have (0 ohms)WHILE PUSHING IT IN(the start switch isa momentary contact switch and will only have contunity while its pushed in)
to check timer again use wiring diagram and find chart that shows various cycles and with timer set to a cycle the two wires is says will have contunity will be indicated by a solid black line on the diagram
Good luck, Gene
Jul 26, 2011 | Dryers
The T104p3 timer is getting power but the clock won't turn and the manual switch also doesn't work. we had a power outage, and the timer has not worked since then.
If I understand correctly, your T104 240Volt Intermatic timer worked fine before.
Now the clock will not rotate.
The manual switch doesn't operate the load.
You checked for electricity.
But did you check for 240 Volts across terminals 1 and 3?
It sounds like the circuit breaker is tripped off on one leg so circuit has 120V and tests positive for power, but not 240V.
Reset breaker all the way over and then click breaker back.
Back to the timer.
If you test electricity at terminal 1 to ground and it reads 120V, that means timer is receiving power from one leg of the 240 circuit.
If you test terminal 3 to ground and it reads 120V, that means same as above.
But unless you test for 240V across terminals 1 and 3, the tests above mean nothing.
Let's understand 240V circuit.
You know all single-phase household circuits require two wires to complete the circuit.
Same is true for 120V and 240V circuits >> each needs two wires to complete the circuit.
Inside the main breaker box are 3 busbars.
There are 2 hot busbars and 1 neutral busbar.
120V circuit is complete with 1 hot wire from either hot busbar and 1 neutral from neutral busbar
240V circuit is complete with 1 hot wire from one hot busbar and 1 hot wire from other hot busbar.
http://waterheatertimer.org/B220C.html
The 240V circuit breaker snaps down over both hot busbars, and then 2 wires come out of that breaker and go to 240V appliance, or to T104 timer terminals 1 and 3.
If circuit breaker is not delivering on both those hot wires, then all along the way you can test for electricity and test will show 120V but not 240V.
So it appears as though circuit has electricity, but circuit will not operate until both hot wires are available to complete the circuit.
That's why you test for 240Volt across terminals 1 and 3
And also test for 240Volt across both wires at circuit breaker.
Going back to timer.
Unless there was lightning strike that fried insides of timer, but somehow left everything else untouched, the manual override should work if circuit has 240V, and Load (lights, motor, fan) is operable.
A simple test is to move circuit breaker wires to another 240Volt breaker and see if timer works again.
If breaker will not reset, you will have to replace 240 circuit breaker, or add a subpanel if your busbars are burned and broken.
http://waterheatertimer.org/How-to-install-a-subpanel.html
Dec 18, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I set my T104R3 on and off clips to desired times and turned the timer on. At set time the timer went off, but the clock stops and does not continue and turn on at the desired time.
The T104 timer is miswired when it does things like that. The 240 volt clock motor is internally connected at the factory to terminals 1 and 3. That means that one of the incoming (line) 240 volt wires (pick one) _must_ be connected to terminal #1 and the other _must_ be connected to terminal #3.
The outgoing (load) 240 volt wires are connected to terminals 2 and 4.
The Intermatic wiring diagrams leave a lot to be desired. I wrote the following tip to help clarify intermatic T103 and T104 timer wiring, I hope it helps:
http://www.fixya.com/support/r3734548-wire_intermatic_t103_t104_timers
Feb 27, 2010 | RTO Intermatic T104R3 Timer Switch 220V -...
Dryer will not start
It is possible that the door switch is defective. Switch is on inside of front panel. If so you have to dismantle dryer to remove switch.This switch will prevent motor from starting. Is timer running? You should be able to hear small motor running near timer. If not, make sure 240 volt breaker is not tripped. Dryer motor and timer only run on 120 volts and heating element uses 240 volts. So, if one side of 240 volt circuit is dead it may be the side of the circuit that powers motor. Try flipping breaker off and on again. If possible, check circuit with volt meter ONLY if you know how to. If not, get a tech to check out.
Jul 21, 2009 | Whirlpool WGD5300S Dryer
Intermatic Timer 240 Volt 50HZ - For International Use Logo
37 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
