Question about Toshiba TP55F80/81 55" Rear Projection Television
When I activate the PIP on the remote, either one of the pic's are black or they are both the same. I am unable to watch a different cable channel. Please advise how to change channels on the PIP. Thanks, Shelly
  • 643 Answers
If your using a cable box it will not work, unless you get two boxes for that tv. You could get a cable splitter and have the cable box on one side and straight cable on the other side.
Posted on Mar 26, 2011
How do you split the screen to watch two different shows at once?
to watch two defferent channel in one screen,u just need to activate the PIP feature of you tv..PIP means picture in picture.
May 20, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
TV has a black square box blocking out the channel
this is probably the closed captioning option, go into the menu and turn off closed captioning, its probably on text....Hopefully this helps
Jul 18, 2009 | JVC RM-C745 Remote Control
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Hi, The quetiopn is about SONY DVD home theatre system DAV-HDZ235. For some reason I have big black box on a TV screen at time DVD playing. The picture appears and box dissapears when I pushong volume on...
Thanks for giving me the opportunity to help. Sounds like you are inadvertently activating P.I.P (picture in picture) with your remote. Perhaps the P.I.P button is next to the volume control. The black box you mention, is a blank channel. That means the way you have your cable box set up, there is no signal coming in to that p.i.p. tuner. Press the P.I.P. button and see if that's what's happening.
If this advise helped you, please give me a rating so I can make my boss happy! Thanks for using Fixya.com
Jan 27, 2009 | Sony HOME THEATER SYSTEM System
PIP
this tv does not have 2 tuners. So you will be unable to get 2 different channels on one screen. I have the same tv. The PIP is only good for watching a dvd/video and tv swapping only.
Apr 08, 2008 | Toshiba 50A60 50" Rear Projection...
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Need help getting PIP to work
You don't have a problem except you need two tuners. You say you have a VCR, which this has a tuner. Set your VCR to TV and and start the PIP and choose your VCR as the second source. You will now be watching two different channels, one from the TV tuner and one from the VCR tuner. Also just to clarify, you should have the cable wire from the wall running to the INPUT on the VCR and then a cable running from the OUTPUT on the VCR to your TV to make this all work correctly.
May 24, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
