Question about Garden
I have a Sears Craftsman High Pressure washer 1100 from 1994 with a broken On/Off Switch and need a new one
  • 1388 Answers
SOURCE: need help wiring new pressure switch for craftsman air compressor
Assuming that you are wiring for 115v. Lets start with the ground. The cord that attaches to the wall outlet will have three wires, green, black , and white. Insert the cord thru one of the openings of the pressure switch and attach the green wire to the ground screw. Next look very closely at the contacts and notice that they are arrainged in pairs. There is a small brass bar with two contacts that completes the circuit for each line. Start with L1 and attach white wire from cord, then attach white wire from motor to the screw terminal that small brass bar bridges to (should be T1). Next attach black wire from cord to L2 and black wire from motor to remining screw. Remember that the small brass bar with two contacts is the bridge and simply connects white to white and black to black. Enjoy
Posted on Dec 16, 2008
  • 34 Answers
SOURCE: Craftsman 5hp 25 gal oil free compressor. Shuts
DID NEW CYLINDER INCLUDE NEW SUCTION & DISCHARGE VALVES? IF NOT, IT MAY BE
VALVE PROBLEM. ALSO MAKE SURE INTAKE
FILTER IS CLEAN.
Posted on Jul 01, 2009
  • 10 Answers
SOURCE: Craftsman pressure washer with honda engine. low pressure
Sounds like pump is not making pressure. Thats why you get flow, but no pressure.
If it sat for awhile, check shaft connection to pump. Sometimes the impeller or shaft will shear partially due to corrosion when stored. Seals on pump valves could be gone too. Get an exploded diagram, usually from owners manual, easily found for this model. Parts list should have "pump repair kit" with everything needed to bring it back to life.
You and a friend put it on the bench to work on it and save your back. The pumps are pretty easy to take apart and put back in working order.
Posted on Oct 26, 2009
Testimonial: "Thanks, I think seals are the answer as it sometimes makes pressure for a minute then goes away. Jerry"
  • 1218 Answers
SOURCE: lid switch is broken on model 11025852400
Good day,
1. There are 2 screws. one on each bottom corner of the control console. The may be hidden by plastic end caps that have to be uncliped. Remove screws, and lift slightly on the console and rotate away from you.
2. Underneath you will see 2 bronze colored spring clips, and a three wire plug. Unplug the three wire connector, and with a decent size screw driver, place in the well of the clips and pop them off.
3. You will be removing the whole cabinet. Top, front, and both sides as one piece.
4. Slide the cabinet forward a few inches, then tilt it over until the front is laying on the floor.
5. There are 3 distinctly different switch arrangements. 2 have a pin on the side of the lid, which depresses the switch. Purchase and replace everything, including the depressing pin.
6. The third type is totally hidden with no depressing pin. It explains itself.
7. Reinstalling the cabinet, is a lot harder than pulling apart, due to alignment problems. Having 2 people helps. The bronze clips take a lot of pressure to re-install as well.
Posted on Dec 06, 2009
odiebugs
  • 949 Answers
SOURCE: need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Posted on Feb 15, 2010
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
How to recoil the spring on a pull start cord for a craftsman pressure washer model # 580 750 400
If no repair manual. It could be spring is broken. So I'd look for spring, and instructions to install spring. That should give you a good idea. I suppose the handle came off and lost the rope inside? Probably need new rope too. Same kind of instructions would apply in how to recoil if it's not broken.
Mar 13, 2015 | Craftsman Garden
DO PRESSURE WASHERS NEED PUMP OIL?
most do but it depends on the make and mode of your pressure washer
Jul 01, 2014 | Husqvarna Original Sears Craftsman...
Were do i purchase replacement attachments
sears sells craftsman and parts . you must be able to just google craftsman dealers. not sure what country your in ? also most rental places has small engine repair or at least know where to purchace parts exspecialy wands and the spray tips .
Mar 17, 2013 | Craftsman Garden
Craftsman 2500psi 2.3 gpm briggs and stratton pressure washer wont start
if it is still within the warranty period , take it to an authorized service agent for a check
if not I would be looking at the fuel system ( water in the carby) or wires to the stop/.start switch
May 17, 2017 | Craftsman 2500 PSI Briggs & Stratton...
Need substitute switch part for sears saw
New
Feb 15, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
I bought an older Model Craftsman pressure washer.Where can I get a Owner's Manual??
You should be able to go to Sears.com and request it in either pdf form or paper copy. Swing by the Sears repair center and you can also request it from them.
Aug 26, 2009 | Garden
Craftsman compresser md 919155730
This sounds like a pressure switch failure. follow the power cord to where it enters the compressor and the switch should be there. you should be able to order a new one through sears service center. Good luck.
Jun 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
