Question about Hitachi DZ-MV750MA DVD Camcorder
Hola, se me ha caido la camara y ahora pone "disco ilegible" en cualquier dvd que pongo. Les agradezco s me ayudas Leticia Hitachi DZ-MV750MA DVD Camcorder w/16x Optical Zoom CAMARA DE VIDEO
  • 30 Answers
SOURCE: Hitachi DVD camcorder
The door might be stuck. Try "helping" it open manually after pressing the eject button. Otherwise, something is probably broken and you might have to call a repairman.
Posted on Apr 09, 2006
49thdiver
  • 3 Answers
SOURCE: hitachi dz-mv550e
Thanks to moonsets on Camcorderinfo.com I downloaded this and it works !!!! Moviealbum SE 3 can be downloaded here; http://users.pandora.be/ivan.dresse...nload/Setup.zip A serial number is required use DRBDT-3FK8-ZF3FNFZ7
Posted on Aug 30, 2007
  • 5 Answers
SOURCE: codecs anyone?
I have the same camera, and found out that the VRO file is just MPEG2. So copy the VRO file onto your computer from your disc. Once its on your harddrive, you can right click on it and go to properties. Re-name your file from VRO to MPG, making sure that you still have the original VRO file in case you need it for other programs. Once I change it to MPG file name, I can use media player to play it and I have a DVD movie maker where i can edit and record to DVD.
Posted on Jan 13, 2008
SOURCE: Finalized DVD
I have a Hitachi DZ-MV730A,do not know how to finalize a disk
Posted on Feb 05, 2008
  • 8 Answers
SOURCE: HITACHI DVD CAMCORDER DZ-MV4000E
some newer model camcorders require u to finalize your disk before it will work on your pc. and you do need the required software for that model. i worked on a couple peeps camcorders and that was just the one step they missed. finalizing.
Posted on Mar 14, 2008
Mi video camara es canon Dc210 DVDcamcoder no acepta los DVD que le pongo de ninguna que puedo hacer
El manual dice que algunos discos no vas a funcionar con la cámara, pero por supuesto no hay nada en el sitio de eso.
Yo sabía acerca de un problema similar, ya que estaba tratando con los discos DVD + RW. He encontrado algo la solución en la web de Canon: DVD-R/RW y DVD + R / RW son similares, pero en general los formatos no interchangable.
Las videocámaras Canon DVD sólo utilice discos DVD-R/RW. DVD-R/RW y DVD + R / RW son similares, pero en general, los formatos no interchangable. Las videocámaras Canon DVD sólo uso * DVD-R/RW o DVD-R DL (DC10, DC20, DC100, DC40 y no son compatibles con discos DVD-R DL). Si un disco DVD + R / RW se carga en una videocámara Canon DVD de la videocámara mostrará un mensaje "Error de Disco" después de que intenta leer el disco.
* Discos DVD-R de doble cara también se puede utilizar sin embargo, cada lado deberá ser inicializado antes de su uso.
Espero que esto le sea de ayuda; recuerde calificar esta repuesta. Suerte.
Sep 26, 2011 | Canon DC210 DVD Camcorder
Hola midvd no lee los discos el laser si funciona pero en la pantalla me dice que no hay disco a donde lo puedo llevar para que lo reparen?
Hola
Su unidad de lector l?ser tiene problemas. Sustituci?n de que es un trabajo especializado, y debe ser realizado por alg?n t?cnico de servicio con experiencia. No ha dado ning?n n?mero de modelo de la marca de su dispositivo. De todos modos, es repararlo por su centro de servicio autorizado, por cualquier technican de servicio con experiencia. Aceptar.
Jun 14, 2011 | Durabrand PDV-709
Hola a todos. Tengo dos problemas con mi jeep cherokee 1990. El primero es que me ha quemado dos headlight switch, se apagan las luces en cuarquier momento y despues no encienden y cuando verificamos...
Hola, Para el primer problema, es necesario instalar un Relay en el circuito de las Headlights, esto ayuda a evitar que el switch se queme, ya que sin este Relay, consume mucho amperaje y esto es la causa del switch quemado. Suerte!
Jan 29, 2011 | 1990 Jeep Cherokee Limited
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
No se conecta al pc
Tu reproductor utiliza el protocolo MTP (m?s informaci?n). Los requerimientos m?nimos para ?ste son:
* Windows XP Service Pack 1
* Windows Media Player 10
Cualquier otra PC que no posea estos requerimientos, no detectar? tu reproductor. As? que la respuesta a tu pregunta seria... NO.
Pero por otra parte, podr?as cambiar el firmware a UMS si tu reproductor lo admite, y si el sitio web del fabricante pone a disposici?n dicho firmware.
En modo UMS te lo detectar? cualquier PC como disco extraible sin ning?n problema.
Espero que esto te sea de ayuda; si es asi, recuerda calificar mi ayuda. Suerte.
Sep 30, 2010 | SanDisk Sansa m240 MP3 Player
Mi batidora no prende
Hola EBANY780, veo tu pregunta es acerca de su licuadora, pero le fue anunciado en la mezcladores KitchenAid. Mi solución puede funcionar, pero posiblemente no.
Usted ha dicho, "Yo pongo [en] mi pincel" - Supongo cepillo de la licuadora de motor eléctrico(s), así que recomiendo que pruebe lo siguiente.
Sólo hay una manera de volver a instalar los pinceles y eso es lo que tanto el asiento correctamente en colector del inducido o no se va a cualquier jugo "al motor. Véase la ilustración de abajo:99839ea.jpg Si te has vuelto un cepillo de 90 grados demasiado, no encaja correctamente y tendrás el poder para el motor.
En esta ilustración se debe permitir volver a instalar los pinceles con confianza. Buena suerte, espero que esta ayuda. Howard, Burke, VA, EE.UU.
Si esta solución ha sido útil, por favor, tasa que, gracias!
- hslincoln
Jul 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
Scanner Mustek mod. 600 III EP -[ Plus
Hola Julian: Eso que comentas es el power de tu scanner, puede ser conectado a cualquier toma corriente de tu casa con el adaptador adecuado y no necesariamente a tu computadora.
Pasa que algunas computadoras como la tuya tiene entrada de power para conectar este tipo de devices para darle corriente a los scanner, parlantes o cualquier device externo que necesite power.
Ese cable lo conseguis en cualquier store de electronica, es un bridge. (un puente de corriente entre tu compu y el scanner)
Sino la otra alternativa es conseguir un power supply para tu scanner. Eso es todo.
Aca tenes el power supply:
http://cgi.ebay.com/15HB-power-supply-ADAPTER-15v-1A-HP-Mustek-UMAX-scanner_W0QQitemZ370092779651QQcmdZViewItem?hash=item370092779651&_trkparms=72%3A1156%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Oct 04, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Hitachi DZ-MV750MA DVD Camcorder Logo
57 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
