Question about Vizio 42 in. LCD TV
How to restart set up wizard on my vizio e420vl..i accidentally inputed cablle as the tv input..and now it won't let me input anything else..i don't have cable..just want to pick up regualr tv channels
  • Vizio Master
  • 8,457 Answers
Go into tv menu goto SETUP go down to Ch.setup enter to pick AIR not CABLE and press enter for scanning for regular Free AIR tv broadcasting channels.
Posted on Mar 26, 2011
Testimonial: "totally helpful and easy to follow am grateful..thx!"
My Vizio E420VL would not power on.
It is possible you have a faulty main board. The main board is in charge of sending a signal to the power supply to "turn" on the set. So assuming your replacement power supply is a working board, I'd lean towards the main board. I would recommend getting a professional diagnoses to be sure.
Nov 24, 2012 | Vizio E420VL 42 in. HD-Ready LCD TV
How do replace a broken screen on a Vizio E420VL 42 in HDTVReady LCD TV
Screen is part of the display panel and means set is finished---cost of part if even available exceeds at the wholesale level the cost of a new set.
Plasma and LCD sets have fragile display panels and can easily be destroyed.
Apr 18, 2012 | Vizio E420VL 42 in. HD-Ready LCD TV
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
My vizio e420vl turned itself off and won't turn back on. When i plug it in the vizio logo lights up amber but it won't do anything else.
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
May 29, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Dec 13, 2010 | Vizio Televison & Video
I just hooked up our Vizio E420VL 42" LCD HDTV.
well if you have cord going to ur u-verse then check your rca jacks red and white and see what inputs they are in and another thing hopefully your sound card has not gone out but let me know what happen
Dec 06, 2010 | Vizio SV422XVT 42 in. LCD HDTV
Vizio 320m. I set it up wrong. Instead of choosing
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
Oct 31, 2009 | Vizio VL320M 32 in. HDTV LCD TV
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
968 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
