Question about Samsung Wireless Security Monitoring System Sew-3030
Hi, We have the samsung wireless video monitoring system SEW 3030, it has been working perfectly up until a few hours ago when suddenly the parent unit said out of range and the picture was lost. We have tried all the wires, turning it on and off, its fully charged, the camera is plugged into the mains. We have restored the factory settings and tried to pair the camera and parent unit but it wont work. Any ideas please.
4 Suggested Answers
SOURCE: Monitor went black
I have same problem. only 13month worked.
Posted on Nov 24, 2010
SOURCE: Our Samsung SEW-3030 won't stop
Adjust your sensitivity dial which is located side of your monitor. It might hard to find suitable sensitivity, but once you find, it will not vibrating.
OR
You can just put sensitivity dial all the way down to turn alarm function.
Hope this helps!
Posted on Sep 28, 2011
dreamerm22
SOURCE: My samsung video monitor (sew3030) says out of range and I have tried everything and nothing works.
I had this same problem all i did on the menu went to the option where it has the monitor and the camera behind it and click on the middle button (select) and it says pair it and some seconds then you click the button behind the camera and that was all i had to do hopefully it solves your problem if not this is the number you can call for technical support 1-877-349-3149
Posted on Aug 21, 2012
My baby monitor wont stop making static noise
Did you try to turn the auto mute on? It is the first option under settings.
Mar 11, 2012 | Samsung Wireless Security Monitoring...
Mar 04, 2012 | Samsung Wireless Baby Monitor Camera...
The monitor on my Samsung sew-3022 baby monitor will not turn on
My AC adapter plug is loose in the socket. We had trouble turning the monitor on before we realized the charging light was not coming on. We were plugging it in and thinking it was charging when it was not. We have to wiggle the plug a bit and find the sweet spot to get it to charge. The plug is a loose fit and I think it has arced across causing the post to build up with soot. It might be a fire hazard but at 5v and 1A, the risk is pretty low. It would probably just quit working before it got hot enough to burst into flames. I'm looking at ways to replace the socket because I think that is the problem. I don't want to send it back for warrantee because I don't want to be without it for as long as it would take the to fix it and return it. I might just buy a second one for the additional camera and use the second monitor.
Feb 27, 2012 | Samsung Wireless Baby Monitor Camera...
When I turn on the volume on my monitor for my Samsung SEW-3030WN I get a really loud feedback/interference sound. How can I eleminate this?
if it has a built in microphone (or you have a microphone near your monitor) go into the mic properties and tick noise reduction (or disable it)
Feb 01, 2012 | Samsung Wireless Security Monitoring...
My samsung sew-3030 won't keep the current date
To update firmware you will need a Microsoft Windows based PC and download the latest firmware on this website:
http://www.samsungsecurity.com/product/product_view.asp?idx=6404.
SEW-3030_mr8911isp-nor+spi_For US.zip (2.23MB)
Once downloaded, unzip files to your desktop and do the following sequence:
1st -> RUN file Generic_V1.0.0.0.EXE (USB firmware update driver)
2nd -> connect your wireless video monitor to power adapter
3rd -> press and hold select (enter) button in the middle of the dial.
4th -> connect USB cable to your PC. (screen will blank white instead of black) this is firmware update mode
5th -> RUN firmware update utility mr8911isp.exe , wait to USB connection (status bar will turn green) and show message ASIC: 0301 Device Connected
6th -> Press Update button and wait...
7th -> Update done! disconnect your device and voila! no more date/time issues and another bonus bugs fixed noticed: lower alarm beep volume, menu text size increased for better reading, temperature sensor more reliable
I Hope it help everyone having problems with this baby monitor
Jan 03, 2012 | Samsung Wireless Security Monitoring...
My baby monitor won't stop vibrating!! about every five seconds it vibrates 7 times.
I had the same issue, I called Samsung, they where great help got right on the line with them. The issue is on the actual camera for the monitor the sensitivity dial is set to high, just lower it and you should be good.
Aug 01, 2011 | Samsung Wireless Security Monitoring...
Our Samsung SEW-3030 won't stop vibrating. How do we get it to stop?
OR
Hope this helps!
Jul 30, 2011 | Samsung Wireless Security Monitoring...
How do i view my Samsung wireless monitor through my computer?
When I installed the drivers for Mac, a software called Mars Camera also installed itself on my computer. I can use it to see what the camera can see. Any chance you might also have installed this software from the enclosed CD?
Feb 19, 2011 | Samsung Wireless Security Monitoring...
SEW-3030 Software does not install from CD.
Try the following to download the Windows or Mac drivers needed to run the SEW-3030:
http://www.samsunghomesecurity.co.uk/downloads.html
I've used to connect the monitor to my Mac. The package (for Mac) also contains Mars Camera, a software that can operate the camera when the monitor is connected to the computer. It was developed by Mars Semiconductors Corp, which I guess is behind the chip needed for the monitor and camera to communicate.
Feb 10, 2011 | Samsung Wireless Security Monitoring...
Samsung Wireless Security Monitoring System Sew-3030 Logo
218 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
