Question about Goldstar WG8000 Air Conditioner
Our air condition is not coming on - Goldstar WG8000 Air Conditioner
  • Robert Mar 25, 2011
    Are you getting voltage to the unit?
    Genius:
  • Goldstar Master
  • 1,033 Answers
Hello, if you are getting 120 volts to the unit and it's dead then you need to check the wiring first and make sure no wires are burnt and loose, also it could be a bad thermostat or selector switch.
Posted on Mar 25, 2011
Why do we get water in the exhaust blower?
an air conditioner does just that, it conditions the air, air contains moisture so the air goes in "Wet" it gets conditioned then comes out "Dry" so the moisture that was in the air before conditioning comes out of the exhaust as a by product, hence why old air conditioners were placed in windows for the natural by product to drip away outside.
Nov 11, 2014 | Heating & Cooling
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
All air stopped blowing in through the vents.
o air coming from air conditioning vents
  1. Check the air conditioner fuse and replace as necessary.
  2. Air conditioner system discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  3. Air conditioner low pressure switch defective. Replace switch.
  4. Air conditioner fan resistor pack defective. Replace resistor pack.
  5. Loose connection, broken wiring or defective air conditioner relay in air conditioning electrical circuit. Repair wiring or replace relay as necessary.
Apr 27, 2010 | 1986 Toyota Camry
The air condition air coming out of the vent is
GET THE INLET COILS CHECKED .THEY MUST BE CHOKED .SO LESS AIR IN MEANS LESS AIR OUT .
Aug 14, 2009 | Heating & Cooling
Air conditioning - a/c fans don't come on, compressor makes squeals, air is not cold.
The Air-conditioning needs to be re-gassed. Take the car to an Auto Mechanic to get the Air-Conditioning re-gassed. They might also need to check it for leaks to make sure the gas stays in.
Jun 27, 2009 | 1996 Dodge Caravan
1994 BMW 318i Air conditioning problem
You need to check the blower motor in car ...
Good luck..
Jan 15, 2009 | 1994 BMW 3 Series
Air conditioning unit not engaging
your air conditioning system needs recharged. im sure of it.
Nov 25, 2008 | 1990 Toyota Pickup
2000 Altima GXE: Air Conditioning does not shut off
air will always come out of vents but unless u have your a/c button pressed in and light on your a/c pump will remain disengaged and not use any more gas try tuneup and check tire press. to regain fuel economy
May 24, 2008 | 2000 Nissan Altima
Goldstar WG8000 Air Conditioner Logo
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
