Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Looking for prop for motor guide stealth electric trolling motor and locking nut model ST350, can you help?
2 Suggested Answers
  • 5 Answers
SOURCE: i have a 37 lb thrust motor guide stealth 5forward
trolling motor parts.com
Posted on Apr 30, 2010
How to change a Propeller on motor guide stealth quick stick trolling motor
copy and paste ( https://www.youtube.com/results?search_query=How+to+change+a+Propeller+on+motor+guide+stealth+quick+stick+trolling+motor )
Dec 09, 2017 | Boating
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
    I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
    Feb 12, 2011 | MotorGuide Standard Motor Replacement...
    I cant seem to figure out how to take my prop off my minn kota trolling motor. there is a plastic nut and a screw in the center of it. they both just turn. ive used a screw driver to turn the screw and...
    I had the same problem tonight. I wound up getting it off by appling a diagional pressure to the prop. That held the shaft screw. Then my Dad turned the wing nut with a neddle nose pliars conter clockwise and it came right off.
    My problem and probably yours too is once inside there is a pin holding the prop to the shaft that was broken. I don't know how to get the new pin back in since it is inside the prop with no access from the outside.
    Jul 22, 2010 | Minn Kota Endura 30 Freshwater Transom...
    Need bigger prop with same pitch as old one
    Hi!
    Minn Kota doesn't supply any other props than the stock ones for a reason....if you install a larger prop, it takes more power to turn it at the same speeds. More power (amp draw) means more heat....more heat means blown electronics. Be careful, in their warranty they state that installing an aftermarket prop will void the warranty. For good reason too! I've seen the damage that can occur.
    Best of luck
    Mike
    Sep 19, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minnkota trolling motor prop removal
    remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Replacement of motorguide trolling motor prop
    Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
    Triton72
    Mar 26, 2009 | Boating
    Removing Prop
    There should be a retainer nut accessible at the rear of the prop (in the center of the prop. Remove this and the prop should slide off.
    Mar 13, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
    120 people viewed this question
    Top MotorGuide Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Ian Summerfield
    Ian Summerfield
    Mike
    Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
