Question about Kenmore 62802 Electric Dryer
Will not start when I hit start button - Kenmore 62802 Electric Dryer
    Sergeant:
    Champion:
  • 202 Answers
You have a bad thermal fuse ... take the back off your dryer and find the two only blue wires going
to a white thermel fuse ...
Posted on Mar 26, 2011
Dryer hit start button and it hums
sounds like a motor is going bad or you have a sock in the blower fan but if it was a sock, it wouldn't work at all
Feb 12, 2013 | LG Dryers
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Correct starting proceedure
before hitting that button, give it ONE full shot of throttle, pull the choke cable all the way out, hit the button...... ONCE.... Mine starts EVERY TIME! When it is WARM, give her ONE shot of throttle, hit the button......
Apr 04, 2012 | 2002 Harley Davidson FXDWG Dyna Wide Glide
I can't figure out how to change from right hand click to left hand. Please tell me how to do it. thanks
start run control panel mouse/ buttons/ configuration
press ok............
cheers
Mar 27, 2011 | Computers & Internet
How do i program it for my xbox
I got one about a week ago, and it works fine for most things... I had trouble with the programing button, since the clear button did nothing ..... to program the controller, you need to hit program button, then hit the buttons you want it to do, the first button you hit will be your start button. like if you wanted to do X Y R R L A, you would hit program and it should light up flashing... hit X Y R R L A and then hit program button again. when you want to use the series of buttons just hit X and it will automatically go through them. Now if you want it to go just normal X again you have to hit program button then X then hit program button again. that should just be the x button all over again.
For the Turbo Button you need to hit the button you want to repeat and then while holding that button down hit the Turbo button..... it will start flashing and boom you have rapid fire and you only have to hold button down to get it to repeat...
Aug 06, 2010 | Intec XBOX CONTROLLER- PRO MINI CONTROLLER...
How do I cancel an order to make it stop printing and clear it out of the system
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jun 23, 2010 | Zebra 105SL Thermal Label Printer
Chance time in cherokee 2005 with navigasion is no time botton
If you have a VIC (Vehicle Information Control), hold the set button down until the hours start flashing. Once the hours are flashing, hit the set button to change the hours until you've got the hours correct. Then hit the Select button and the minutes will start to flash. Hit the Set button until your minutes are correct and then hit the Select button again whereby the AM/PM button will flash, hit the Set button until your time's correct, then hit select to move to the day, date and year and when you're finally done, (after all the hitting of the SET & Select buttons, just hit the Select button and nothing will flash and your time is set. Should you have a radio that displays the time, push down and hold the TIME button until the hours begin to flash (with the radio turned off), then turn the volume wheel until the correct hour is displayed. To adjust the minutes, turn the Tuning knob until the minutes are correct. Once you're done, don't touch any of the buttons and the clock will display the correct time on it's own...when you've released all the buttons and dials.
"00 Buck"
Nov 06, 2009 | 2005 Jeep Grand Cherokee
How can I reset the key signal on my Panasonic FP-7722?
user preset button, original size ledger and the number 3 button get's you in to service mode, F1 go to F7 by hitting 7 and start button, touch 26 and start, change number value to 120,000 and hit start button. Exit service mode by hitting user preset button and clear button.
Sep 25, 2009 | Panasonic FP-7735 Black and White Copier
Can't scan a document
Maybe it wants you to hit a start button in the computer program, to start the computer receiving the scan. Try to get an owners manual, sometimes there's one in the install cd.
Apr 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
Kenmore 62802 Electric Dryer Logo
49 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
