Question about Black & Decker Dewalt #D55155 2HP 4GAL Eleccompressor
Dewalt d55155 replacement regulator kit I need a installation diagram as parts were loose in the bag from dewalt. Approx 7 parts 1 diaphram 2 springs 1 adjusting knob and 2 other small plastic parts 1 teflon o-ring help!!!!!!!!!!!!!!!!!!!!
  • 1388 Answers
SOURCE: dewalt D55155 air compressor regulator installation
The d55155 unit suffers from regulator problems due to weakness in the design of the manifold. The manifold parts are very light duty metal and will break during installation if not carefull. If you can return the parts to dewalt it may be more efficient to to use a generic pressure regulator from www.grainger.com for about 20 bucks and mount using a couple of 1/4" tees directly off the pressure switch. Remove the hose from the pressure switch that feeds air to the manafold . Install parts so that the quick disconnects, guages and new regulator are accessable from the side. It will not be pretty but problem will be solved for long term. We repair other brands that come with control panels using the same method. Pressure regulators built into a manafold will fail. For demanding customers we have recreated the manafold using 1/4 pipe fittings and refit the gauges and grainger regulator into panel.(lots of work) But leave the safety unloader at the pressure switch. If all you need is a good functioning compressor same time and money and mount to side. Good Luck and email if you have questions or other issues with your dewalt.
Posted on Feb 26, 2009
mickey813
  • 472 Answers
SOURCE: Dewalt D55155, I want to change oil, what type and
use30 wt oil and fill it up till it comes 1/2 way up in the bubel
Posted on Nov 05, 2009
Testimonial: "thank you, that makes sense"
  • 4234 Answers
SOURCE: Dewalt D55155-QS 220 volts can it convert to use 115 volts?
The short answer unfortunately is no. The internal motor that drives this compressor requires 220 and will not work properly with 110. Your only option would be to replace the motor with one compatible with 110. The cost of that would approximate a major portion of a replacement unit.
Sorry about the bad news.
Dan
Posted on Jul 08, 2010
ashfaq_atlas
  • 6 Answers
SOURCE: dewalt air compressor d55155 rattles and doesnt
Dear,
You required to replace the valves assembly,
Cylender and piston also need to check for any damages before ordering parts for valves.
Regards
Ashfaq
Posted on Jul 22, 2010
nampaboat
  • 150 Answers
SOURCE: dewalt emglo d55155 air compressor-what
Need to use air compressor oil it is available at you local hardware store in the tools department.
Posted on Feb 06, 2011
I have a D55155 compressor. When completely empty of air the guages do not read zero, should they or does it take awhile for them to go down. Also where is the pressure switch on the D55155?
GUAGES: Guages read exactly what pressure is on them at the time, there is no bleed down time. If the reading is off at zero it will be off accross the dial. The case may have been hit to knock the guage out of allignment or the needle is bent but that's hard to do unless the plastic cover is broke off.
PRESSURE SWITCH: The pressure switch is the black box under the large pannel right behind the quick connects.
LEAKS: Leaks cause compressors to cycle on and off frequently. They are easily found with soapy water in a spray bottle. The guages and quick connects should be replaceable with off the shelf (Home Depot, Lowes, tool repair shops) similar parts.
REGULATOR: If adjusting the regulator does not affect the pressure at the quick connects, and on the guage, it may be stuck or broken. This could also be the place to look for a leak. Dewalt does make a regulator repair kit, part number 5130027-00.
Oct 31, 2012 | Dewalt Air Tools & Compressors
I have a DeWalt D15155, Type 2 compressor. Regardless of setting of the regulator, the downstream gauge shows the same pressure as the tank gauge and there is constant air escaping at the...
Sounds like the diaphragm is leaking. It is use pipe threads , so power down empty tank and remove the mounting bracket and gauge and unscrew the regulator A complete regulator is 5140442-76 You mat be able to find parts. Check ebay. anew one is about $100
Apr 21, 2017 | Black & Decker Dewalt #D55155 2HP 4GAL...
I have d55155 and cant get over 60 psi, it never shuts off. how do i tell where the leak, o ring, or teflon tape should go. should the release valve be in a certain position? it seems down all the way
Could be leak or faulty valve plate in head. Use soapy water and spray all fittings including drain valve and pressure regulator. Repair as needed. If no leak found suspect problem with compressor. Try simple test, with compressor running and has reached max pressure (60psi) remove air filter and feel intake for suction. Be carefull could be hot. The suction should fairly strong. If no suction or actually feels like air is blowing out of intake, suspect valve plate. Parts are available at dewalt service center or www.toolpartsdirect.com. Good luck
Sep 22, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Dewalt air compressor d55155 rattles and doesnt build pressure
Dear,
Regards
Ashfaq
Jul 09, 2010 | Dewalt Air Tools & Compressors
Dan
Jul 08, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Dewalt/Emglo D55155 compressor screeching and breaker blown
Sounds like it isn't getting oil on the bearings. Take it apart yourself,after you get a diagram of it and find a parts source.
Mar 22, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Dewalt D55155 air compressor regulator installation
Feb 19, 2009 | Black & Decker Dewalt #D55155 2HP 4GAL...
Black & Decker Dewalt #D55155 2HP 4GAL Eleccompressor Logo
347 people viewed this question
Top Black & Decker Air Tools & Compressors Experts
John Trevino
Wayne Fellows
Wayne Fellows
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Black & Decker Air Tool and Compressor Expert? Answer questions, earn points and help others
