Question about Thermador 31 in. SGS304Z Gas Cooktop
Gas burner not lighting
One of my burners is not sparking. There is no clicking sound and the burner will not light. The other burners are fine but this one will not come on. I can put a flame to it and use it that way so gas is coming out but it will not light automatically. HELP!!
  • 659 Answers
Make sure the burner ports are not clogged. and the caps are properly positioned. clean ports with a wire or a straightened paper clip if clogged.
make sure the igniters are clean and dry
Posted on Aug 03, 2008
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
When i turn the knob for the front burner, there is a clicking sound (igniter), but the burner takes a while to ignite. the other burner work fine. is the front burner igniter malfunctioning?
Hi, Make sure the ignitor is actually sparking on this burner. Try removing the cap on the burner and scraping/sanding the bottom side where the ignitor spark hits it. Sometimes these will get a film on them and not let the spark work properly. If there is another cap the same size, you can try switching them and see if the burner lights. If that does not help, remove the cap again and see if there is something plugging the orfice at all.
I hope this helps you. Please let me know if I can assist ou further.
Vic
Jul 04, 2009 | GE Profile JGP636 Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
One burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Nov 30, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
Thermador 31 in. SGS304Z Gas Cooktop Logo
536 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
