Question about VisionTek ATI RADEON X1300 256MB DDR2 PCI Express Graphics Card
I know my PCI card, Radeon 1300xt is three yrs old, works great but the fan has recently started to grind loudly so I took it out, can this be fixed? Or do I have ti invest another $120.00
    Scholar:
  • 78 Answers
You can attempt to fix it, but be careful as a video card is a fragile piece of electronics and can easily be damaged. Do not attempt to fix your fan unless you absolutely sure you can do what I suggest and that you understand it.
The only tools you are going to need are a can of compressed air designed to clean out dust and a bottle of "three in one" oil. These can be bought at just about any hardware store, or even big-box stores. You are also going to need a screwdriver to remove the fan assembly.
Remove the fan assembly first by removing the screws holding it in place. Then, blow your entire fan assembly clean using the air can.
After you have done that, look for the back of the fan itself. There should be a piece of tape or plastic that can be removed covering the back of the fan. Remove this, then place one to two drop of your three in one oil into the hole that the tape was covering.
Let the fan assembly sit with the hole facing up for about 30 seconds. Then, spin the fan around a few times, and let it sit for another 30 seconds. This will ensure that the oil fills in all the little spaces it needs to lubricate.
Once your fan is done sitting, replace the tape (or put a new piece of electrical tape where it used to be, especially if the old tape is a little lose when you put it back on). Put the fan assembly back onto your video card in the position it was before you moved it. Put the screws back in the holes, and screw tight.
Put the card back in your system and try it out. If the noise has stopped, congratulations, you just saved yourself $120! If not, then your fan is either lose or there is something else wrong with the card, and it's time to start saving.
Let me know how things go. If you need any further support, leave a comment in this thread and I'll get back to you as soon as I can.
Posted on Mar 25, 2011
  • 902 Answers
Yes it can be fixed but i would highly reccomend upgrading you can get a nice card for thats far more powerful for under 100 bucks from tigerdirect.com
My ati radeon 5450 series card getting overheat
you could be pushing the video card to its max, and/or there might be something wrong with the heatsync fan
Jun 28, 2012 | ATI RADEON HD 5450 DDR3 PCI Express (PCIE)...
Radeon X1650pro suddenly stopped functioning
You may have to uninstall prior drivers and re-install the most current. If you have been operating this card with Windows 7 then, it must be compatible. http://support.amd.com/us/kbarticles/Pages/CatalystAGPHotfix.aspx This is AMD's link for your card. If it is indeed an AGP card I would try the driver listed for your operating system. It worked with Windows 7 but the current drivers may not work. If you have upgraded your drivers in the past yourself, you may want to see if you can find the last compatible driver that worked for you and/or you may want to start over altogether if you have the installation CD. You may also want to try the Vista driver, which will sometimes wirk with Windows 7. If it's at all possible, you might want to test the card on a family or friends computer with the AGP slot. Good luck. Dave
Feb 05, 2012 | ATI RADEON X1650 Pro, (512 MB) PCI...
I am a gamer and p5vdc-mx has only agp slot and i want 1gb vga card but it is harder to find in agp slot i find only pci express x16 cards can i use riser card to convert agp to pci e x16
Hello
I dont think there are any agp to pci ex riser cards.As pci e x16 is part of the motherboard circutry.
There are pci to agp riser cards.If your going to be playing some of the latest games.Most games in the past 3 yrs require a pci x16 vid card.
I suggest geting another motherboard,chipset,and memory.Along with a Pci e x 16 card min 512mb.
Sep 07, 2011 | ASUS P5VDC-MX Motherboard
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
Thanks for using FixYa.
May 14, 2011 | Computers & Internet
My graphics card will not install. (Asus ATI Radeon HD5450 Silence). My computer is compaq presario sr1620NX with integrated graphics. (ati xpress 200 chipset) I disabled display driver in device manager...
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
Mar 26, 2011 | HIS RADEON HD 5450 Silence 1 GB DDR3 HDMI...
My computer will not boot properly or show video with new radeon hd 4550 card installed. How can I fix this? I've unistalled previous card's drivers and think I've disabled on board adapter, but its still...
The pci express slot on that computer is an option, so it may not be enabled automatically when shipped, I would suggest rebooting and go into the BIOS settings and make sure the PCI slot is enabled. Then strile F10 to save and exit, reboot and try it again.
Jan 11, 2010 | Gigabyte RADEON HD 4550, PCI Express...
A8N-SLI Premium & NVIDIA GeForce 7800GT
Sounds like your getting conflicts with running two different card drivers. I've never heard of running a PCI and a PCIe card at the same time.
Jan 09, 2009 | ASUS GeForce 7800GT, (256 MB) PCI Express...
Need new card, system requirements confusing
Radeon X800 XL is a PCI-E (PCI-Express) card, you can replace it with any current ATI or nVidia video card that uses the PCI-E slot. Since you already have a PCI-E card before, I would bet you already meet most of the system requirements.
Nov 13, 2008 | ATI RADEON X800 XL, (256 MB) AGP Graphic...
ATI RADEON X800 GTO AGP
can u take it out boot up for 20 sec shut down reaset it in and plug it in useing differt plug ok push it in good then cheak fan on it blowing or not if not unplug it get a fan on it
Jan 23, 2008 | ATI RADEON X800 GTO, (256 MB) PCI Express...
Tried To Install New Card, monitor not responding.
Tech is suggesting that you pressed too hard while switching back & forth & may have hurt the motherboard by bending it. This a common problem. I can only suggest that remove your old card & clean the PCI slot with canned air. Carefully reseat the old card pressing evenly downwards till the card is seated. Use a flashlight & check where the card connects to the slot. It should be level across the PCI slot. Do this while the power cord is unpluged from the PC. Plug the power back in & start the PC.
Some video cards require extra power. Your newer card may need a four pin power connector to run. Please check the instructions that came with the RADEON X1300.
Dec 31, 2007 | VisionTek RADEON X1300, (512 MB) AGP...
VisionTek ATI RADEON X1300 256MB DDR2 PCI Express Graphics Card Logo
73 people viewed this question
Top VisionTek Computers & Internet Experts
J John
Computer Links
Are you a VisionTek Computer and Internet Expert? Answer questions, earn points and help others
