Health & Beauty Logo
Posted on Mar 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My father in law has a scooter from merit and it does not go very fast anymore. he said he has charged batteries and changed fuse but still doesnt go as fast as it uses to.
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Mar 25, 2011
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288510
Points
1801
Shell Could be a couple of things but I would suspect the throttle pot. If the scooter is 4-5 years old or older the motor brushes might need replacing. If dad has the scooter outside and it gets damp the brake assembly might be sticking also If it gets rusty. If Medicare paid for dad's scooter I would contact a repair service to check it out and repair it since Medicare will pay for 80% of the repair cost. You can call Repair Express @ 1-877-581-3733 to see if they have a tech in your area or contact the provider that sold your dad the scooter to see if they have a repair service Hope this helps
New Battery for my DL 5.2i Merit Mobility Scooter
12 volt 35Ah Gel battery. Lots of places to buy. Have you had it load tested? Isn't it holding its charge. Not lasting long enough?
https://www.google.com/search?q=battery+for+my+DL+5.2i+Merit+Mobility+Scooter
Why dose my battery charger start for a second and click of
Could be scooter battery voltage is too low for charger to charge battery.
(It is a problem with gel cell batteries I have got a scooter that won't charge at all at home am going to try jump starting with another battery to fool the charger but I might have to buy new batteries.The Nursing homestaff took the scooter off my father in law and left it in the shed to get nice and flat instead of leaving it on float charge I should send them a bill for new batteries
I have a merits s131
Put the unit in drive mode (engage the brake) and try again. If one way doesnt work, try the other way. If this doesnt work you may have a faulty brake switch or brake wiring. Replace both and try again.
Merit dma mobility scooter
hi, okay so you got a onboard charger ? right there should fuses fitted to either on of the three wires coming out of the charger ? unless the charger is itself is faulty ?
Regards
Rob
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Have bought a second hand DMA Tinto S534 mobility scooter for my father and would appreciate an instruction manual or at least some basic information.
Hi peters_17,
Just bought one of these myself second hand, managed to find this on that t'interweb thingy.
http://www.merits.com.tw/upfiles/news01191893408.pdf
You may not need this anymore, but, could come in useful for someone else.
Regards.
Kevin
2helpful
I have got a merits mobility scooter when i try and charge the battery it just keeps blowing the fuse
are you placing the battery to the right terminals .. cause if positive is on positve then it wont blow up the fuse .. cahck and confirm
i hope this helps u
2helpful
My father-in-laws gogo will be not used for several months while he's in florida. how should the battery be stored/charged while not in use?
Charge the batteries fully and remove the battery pack from the scooter. About once a month charge the battery pack. It shouldn't take long to charge since you are not using the scooter Don't overcharge when the light on the charger turns green turn it off and unplug it from the battery pack. This should keep the batteries fully charged and fresh when FIL gets back home. Hope this helps you
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
