Question about Samsung 50 in. Plasma TV
I have a samsung pn50a650t1fxza plasma tv. i have blue, green, and black lines running vertically down the right hand side of the screen. saw on another post that it could be the lower buffer board?? if this is true can i get a part number? i replaced a bad capacitor on the y main already. and the y main is buzzing a little louder than what it should be, even before replacing the bad capicitor. all the other boards look fine. any help would be greatly appricated. thanks.
  • 2 more comments
  • austin r Mar 25, 2011
    Picture is perfect other than the lines, dosent go out and audio is fine as well
  • austin r Mar 26, 2011
    Black lines are about 2in, grn and blue lines are thinner. Plus there is a slight hint of plasma burn when u white out the burn protection. What is the pdp panel #? Thx
  • austin r Apr 01, 2011
    Replaced buffer boards, still have lines about 2in in width, looks like the tape carrier pkgs may have shorted out. Would that cause the lines? Any way to replace those? What is the white paste under the tape carrier pkgs? Thermal paste?
    i replaced the two buffer boards, still have same problem. when i removed the old buffer boards, i noticed that the tcp(tape carrier packages) may have shorted out because of the lack of white goo under the strips going to the pdp panel. what is the white goo? thermal paste? still have 2in lines on tv after board switch. could the shorted tcp packages be the cause or is the whole pdp panel shot? can the tcp pkgs be replaced? sorry so many questions, just trying to figure out what happened. thanks
    President:
  • 1,654 Answers
Have you lookes at this site. if it is not board related it can save you some money. This has helped many people who thought thier sets were broken.
www.jscreenfix.com/video.php . You can burn these and save them on dvd as well.
Well by reading your post I see you already understand the issues with the bad capacitors in these sets. well you may have more. The lower buffer board can cause this issue,
Part numbers as follows.
PART TYPE - E-Buffer Board
Assy Pdp P-e Main Buffer
PART NUMBER - BN96-08756A
BOARD NUMBER - LJ92-01532A
PCB NUMBER - LJ41-05517A
I am posting a link to these parts for you to compare with ones you take out. Also if I were you I would replace both X and Y sustainers. if you fix or replace one the other one soon follows, especiall if it starting to buzz on you.
Posted on Mar 26, 2011
  • Dcramer531
    Dcramer531 Apr 01, 2011
    Are you speaking of the ribbon connectors that connect the boards? Yes they should be replaced with the boards. The paste must be an electrical grease that has hardened over time with heat. I am starting to wonder if the panel on this set has not gone bad. I am going to start looking through some old repair logs and see what else we can do. This is the aggrivating part of this job, when these companies sell this stuff with full knowledge they won't last and they don't like to support people who repair them.
  • Dcramer531
    As you probably know, the TCP (tape carrier package) IC. These are responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. the white goo your refering too must be either corrosion or the bonding material for the chips and the tcp. I am not familiar with seeing this in the past. The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Since you have it open, try pressing on these connections in the area of the lines, there may just be a bad connection, if not then the TCP could be the main issue from the start. There have also been issues with the solder on the fuse connections on the back of the driver boards, if this is the case, just a little solder will fix the issue.
    I will include some reading on this issue as there have been problems along the same line as yours in the past. Most seem to come from these TCp's and display panels. I am also going to include a place that rebuilds them for a very reasonable price. In my inxperiance on Plazma's. they a re great, ,love the picture, but when they start heading south the don't seem to want to stop. These can be repaired like new but how long the repairs last is anyone guess. If it were me, I would rather spend my money on a new replacement rather than throwing it at an outdated system. Plazma's are on the way out and will soon be hard to find. The new LED, LCD's are much better than their predecessors and getting better and cheaper every day.
    www.fps-europe.com/repair.html
    Display Assembly" can be sent tp PTS, Indiana and rebuilt for $87.
    Andrews Electronics sells it for $267. + s&h. These prices are not an accurate price as I have not dealt with them for a while but they can give you a quote is you chose to go this route.
    Genius:
  • 1,112 Answers
The part number you are looking for is BN96-08757A and BN96-08756A, usually with plasmas if the lines rare less then 2 inches in with this is not an indication of a bad buffer board but PDP panel. If the lines are at least 2 inches in with then you very well have a bad buffer board.
  • Lavell Turner
    Lavell Turner Mar 31, 2011
    The PDP panel is a very expensive part, but for FYI the part number is BN96-14592A
  • Lavell Turner
    If the lines are two inches wide then you problem resides in the buffers.
    Genius:
  • 1,622 Answers
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Posted on Mar 25, 2011
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
How do I fix a Samsung un55c8000xfxza that has been through a fire? The TV still operates fine but the screen is dark on one side and has vertical lines on one side.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 30, 2016 | Samsung Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Samsung  50 in. Plasma TV Logo
351 people viewed this question
Jerry Greenberg
Jerry Greenberg
