Question about HP Compaq nc6000 Notebook
How do I get a donated HP nc6000 up and running
A large company donated 3 totally wiped out HP nc 6000 computers to the ambulance service where I am the director. How do I go about getting them up and running. I don't even know where to begin. Thank you.
  • Richard Finch May 11, 2010
    When you switch the laptops on do you see a screen with three options written in white across the bottom? one should be "Press F11 or F12 for system recovery" or something similar.
    Genius:
  • 1,689 Answers
You have to have an operating system, this can be purchased from any computer shop, you may get an enterprise edition so that all 3 computers will just use a single CD.
Windows XP or Vista if it can get along with hardware requirements.
good luck hope this helps
Posted on Aug 03, 2008
Computer compaq nc 6000 powers on for about 8 seconds, turns off
Could be either the power supply, the power supply connector plug on the motherboard, or a defective/loose stick of RAM. Is the connector on the computer wiggly? If not, can you get access to a multimeter, so you can check the output voltage of the power supply?
Jun 16, 2011 | Compaq NC6000 Notebook
My hp compaq nc 6000 is running in safe mode, how can i turn this off plz plz help me!!
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 11, 2010 | HP Compaq nc6000 Notebook
Nc 6000 speakers & headphone working together
1.Switch inside the headphone jack is jammed
2.Could be(less likely) Audio CODEC chip on motherboard is defective.
May 25, 2010 | HP Compaq nc6000 Notebook
I cant find driver for my hp compac nc 6000 labtot base system device
this device drivers are related to chipset, contact manufacturer for chipset drivers or run windows updates from the below url:
http://update.microsoft.com/windowsupdate/v6/default.aspx?ln=en-us
Mar 27, 2010 | HP Compaq nc6000 Notebook
Compaq NC 6000 on XP SP3 - Ethernet Drivers & Wireless Drivers
Limited connectivity means your pc not able to connect to the preffered network.................
wi-fi also not working....................
there is a problem with your router not from pc.
Apr 05, 2009 | HP Compaq nc6000 Notebook
Please help
could be a problem with the battery, power adapter, memory or motherboard. Remove the battery and try turning on the computer with just the power adapter. If no go, test another power adapter. try another battery. Reseat the memory modules, or try using other working memory modules. You may also check this HP support site: http://tinyurl.com/dn44m2
Feb 01, 2009 | HP Compaq nc6000 Notebook
Compaq nc 6000
check for any utilities that might be installed by hp/compaq ... you can also check the control panel for anything referencing power management (but not the windows based one)..
You can also check the BIOS ( i think hitting F2 or F11 once the laptop boots up) and go through the options.
Jun 15, 2008 | HP Compaq nc6000 Notebook
How do I ascertain if my nc6000 has a wireless modem
normally, laptops have an internall integrated wireless modem. All you should have to do, is enable the wireless, by pressing Function F6 or going into the network connections window and enabling the Wireless form there.
Apr 14, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
