Technics receiver SD-S936 has no sound at all. This happened once about a year ago and now it is completly out. I see the fan in the rear is not turning. Is there an internal fuse? This system was new 1995. Thanks
5 Suggested Answers
worldvet
  • 859 Answers
SOURCE: Fan does not work, light does
Your remote uses a slightly different band of IR for one and the other functions; lamp or on/off. This IR lamp or the circuit that controls the IR lamp has failed. You will need a new remote.
Hunter is good about making replacement parts available but as you said this is five years old. You may have to look for an after market seller on Ebay and chances are very good you can find a new one there.
Try Hunter first:
From Hunter Customer Care
Email:
Use Our Contact Form
Phone:
1-888-830-1326.
Monday-Friday 7am-6pm CST
Regards,
Worldvet
Posted on Jun 03, 2008
marsrover
  • 682 Answers
SOURCE: My technics se hd 51
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
Posted on Jul 13, 2008
  • 92 Answers
SOURCE: Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Posted on Oct 14, 2008
  • 336 Answers
SOURCE: receiver says power overload, turn system off
It probably needs soldering of the voltage regulators and/or output IC.
I think that model has an access panel on the bottom (it may need to be cut out then rotated and screwed back on when done).
If it doesn't have the panel the main circuit board needs to be taken out to access them.
The regulators and output IC are mounted on the main heat sink. a little soldering and it should be good as new.
Posted on Feb 17, 2009
  • 583 Answers
SOURCE: Problem with subwoofer and one off the speakers.
just check if the wires are cut off somewhere or the internal connections loseened up.check this out.
Posted on Mar 13, 2009
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Technics Receiver Nonfunctional - Click, then nothing.
I'm not sure what entry will be emailed to you, so I have repeated the "solution" from the other entry below. Please only update one.
Thanks,
Dan
Initial entry:
There could be a number of reasons for this. It woyld help if you could indicate what resistors you changed. The circuit designation should be marked on the PC board. Please post those here and I'll look further and provide some possible solutions.
Thanks,
Dan
Jul 20, 2009 | Technics Audio Players & Recorders
Technics SA-GX350 Nonfunctional - Click, then nothing.
Please update the initial posting and continue the diagnosis there. The initial response is repeated below.
Thanks,
Dan
Initial response:
Thanks,
Dan
Technics Surround Receiver - Clicks, but doesn't function
Thanks,
Dan
Jul 20, 2009 | NAD 712
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
Oct 14, 2008 | Technics SL-1210 Turntable
Turntable turns, but there's no sound.
Well, the motor itself is completely separate from the sound. The path of the sound is basically
Styli -> Cartridge -> Tonearm -> RCA Cables -> Input Source
I would say start from the beginning. Check your stylus. If it's ok, then that means your Cartridge is probably ok. Make sure you have a secure connection from the tonearm to the cartridge assembly.
There really isn't much else to it.
If you cannot get it to work, I would suggest taking it to a service center for assistance.
- OPTiC
Electronic Repairs & Service
A DJ Pro Audio Co.
Sep 21, 2008 | Technics SL-BD22 Turntable
Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
MP3 connection to receiver
absolutely! any audio device using wires can. connect the RCA plugs into the back of the Technics "LINE IN" jacks...the MP3 end may be a 1/8" mini stereo plug (widely available complete cord)
May 30, 2007 | Technics SH-AC500D Receiver
218 people viewed this question
 Grubhead
Grubhead
