Question about Zyxel Computers & Internet
Hi, my problem is when i log in to the configure interface( when you type 192.168.1.1 or something like that into the address bar) i log in fine, but in the dark blue area which is supposed to have the options like maintenance, security, etc, well it's not there anymore, it was working fine before i "factory reset" the system, now nothing will appear, i've already tried reseting the modem, but still nothing, can you help? i have a zyXEL modem and the modem model is P-660HW T1 v2
    Problem Solver:
  • 17 Answers
Did you removed your router and currently using a modem? if that is the case then the whole User Interface would be different when you open that address 192.168.1.1 because this could be a linksys router's default gateway address and it was removed from your network.
Posted on Mar 25, 2011
How to change my router's MAC address Netopia 3397G
Using a router is a great way to create a home or office network without having to spend a lot of money.
As long as you have a broadband Internet connection through an Internet service provider, you can use a router to get all of the computers in your home or office connected.
If you have chosen Netopia as your router brand of choice, you will have to configure it to make your network operable.
Power on your Netopia router, broadband modem and computer.
Open your Internet browser.
Type the router IP address, 192.168.1.254, into the address bar. Hit "Enter" on your keyboard. Log into your Netopia router with the username and password assigned to you by your Internet service provider.
Select "Expert Mode."
After entering expert mode, you will see a menu bar at the top of the configuration window.
Click on the "Home" tab. Many Internet service providers will ship your Netopia router to you preconfigured.
If it is preconfigured all of the fields, such as IP address, subnet mask and default gateway will already be populated. If the fields are not populated, proceed to the next step.
Click on the "Configure" tab. Select "WAN." Select "ATM." Enter the "VPI" and "VCI" numbers provided by your Internet service provider.
Choose your encapsulation option.
For example, "Routed IP," "PPPOE," etc... Click "Submit."
Select "WAN" on the left side of your configuration window.
Choose the "VCC1" option. Select the option to "Enable Interface."
If you do not have your own IP address, choose the option to "Obtain an IP Address Automatically."
If you do have your own IP address, uncheck the automatic IP address box.
Type in your IP address if you have your own.
Enter your subnet mask.
This information can be obtained from your Internet service provider.
Select the "NAT" option if you are using your own private IP address for your network connection. Click on "Submit."
Ensure that there is a check in the "Gateway Option" box and "IP Address" is selected as the "Interface Type."
Type in your "Default Gateway" address.
This can be obtained from your Internet service provider.
Click "Submit."
Select the "Configure" tab at the top of your window. Select "LAN."
Select "Enable Interface."
Type in the IP address for your router and subnet mask. Click "Submit."
Click on the yellow caution symbol on the top right hand side of your window to save all configuration changes.
Click on "Save."
Restart your computer for the changes to become effective.
http://www.netopia.com/support/hardware/technotes/CQG_121.html
May 10, 2013 | Netopia Computers & Internet
D-Link DES-1008D 8-Port drivers
Drivers are not required, the device is a networking device and doesn't interact with the OS directly anyway.
What you might be looking for is the Web Interface that allows you to change settings, update firmware etc.
By default most are configured to either 19.168.0.1 / 10.0.0.1 / 10.1.1.1
Open your web browser, type one of those into the web address bar until you find the one that brings up the web page, from here you should be able to configure a few things.
If you are unsure click start > run > type: cmd > hit enter> a dos prompt appears, now type: tracert www.google.com
You will see IP addresses appear as the computer traces the path the packets are taking to reach google, what you are interested in is the first address that is in that list, that should be your switch ip address and all you have to do now, is type that address in your browser address bar. This should now bring up the configuration page for the switch.
Still unsure of the address, head to D-links website and find the support link and search for your model of switch, from here you can bring up the detailed users guide which will contain instructions on how to access the Web interface also.
Apr 15, 2013 | D-Link DES-1008D 8-Port Ethernet Switch...
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Hi i have trendnet te100 s24 switch and i want to do some configurations on vlans but i do not known how to do that especial getting into the switch interface can you help on this.my regards to you
Usually all those switches are plug and play ..and do not need much configuration ..but if you want to make changes or you changed the way you connect to the main internet source ...you have to use the same computer that was used first for configuration ..(it will be seen as admin ) ..and the log to the settings will be made the same as for a router..Look on the back of the switch ..and see what IP address has from the factory ..and type the IP address into the browser and hit enter..
for example in internet explorer ..write on the address bar ..:
http://192.168.1.1
(this si just an example ..but the ip for the switch will be written on its sticker
it will take you to the log in page ..and in there if nothing was changed .. ..you have to complete the lines with the words admin ..and password..or with the ones you selected when you first configured it ..
In case you forgot all these..it should have a hidden button that will allow you to reset it ..and after that it will be to the factory defaults and will accept the IP on the sticker and the words specified in the manual for login ..to settings ..or ..will go to settings without the log on screen .
Nov 16, 2011 | Trendware TRENDnet TE100-S24 10/100...
How do i set up a password for my wireless internet router?
Hi Joshan,
Hi I got your issue, to enable the security on your router , you have to log into the interface of the router you have.
Inorser to log into the interface of your router, you have to check what is the default gateway address of your comp , to check that
click on start menu---> Go to RUN--> Type "cmd" and click ok---> You will get a command prompt window , in that type "ipconfig" and enter, you will get the default gateway address
Then open your browser, ex: Internet Explorer
In the address bar type in the default gateway address ex:192.168.2.1 and enter
It will show your router interface, choose the option security in the interface.
there You can select any security option you have in your router ethier WEP/WPA PSK.
Thanks,
prema
Sep 27, 2010 | Computers & Internet
I am trying to connect my laptop to my home computer and required to enter a "security key." How do I find the security key on my router?
well its simple to find the security of your router by logging into the web interface of your router...
first check what is the default gateway address of your router, then enter the address in the address bar of your browser...
you will be seeing the web interface of your router...
go to security options on the interface and find yourself what is the security key...
click here to have a look at BELKIN router settings... this will give a hint to how to configure your router by yourself...
Aug 02, 2010 | Westell Wirespeed VersaLink...
How do I put a password on my d-link 300 Dir Router
You need to access your router's web configuration interface. To do this, you need to connect a computer directly to your router and visit http://192.168.0.1 using any web browser.
When prompted for a credentials:
user name = admin
password = <blank> leave blank
When you successfully access the interface, you can set an admin password so that not everyone can access the administration page.
Feb 12, 2010 | Office Equipment & Supplies
I need information on how to configure my 2wire 2701 HG-B modem for wireless access
Log into your router. Click on home network. Status at a glance box, click on edit settings under wireless settings. Under setting click enable SSID and Wireless network security. Your WEP key is on the side of your router. The number above the second bar code with brackets around it.
Hope this helps you.
To log on to your router type the routers ip address into the address bar. If you don't know it....click start....run...type cmd press enter....type ipconfig /all at command prompt...press enter... look for default gateway address.... type that number into the address bar of your browser.
Jan 28, 2009 | 2wire 2700HG-B Router (2700HGB)
I need to know how to configure link proof radware
Hi Nalinfrancis,
One way you can config the LP is to log on to the serial interface and then configure an IP address to the first eth port that is available. Then connect directly to the port using a crossover cable depending on the laptop or pc that you use if it can switch put your laptop/pc on the same network that you configured on the port. Then connect via your browser to the IP address assigned to the LP. Logging with you default username and password. From there you can do all the configuration via the web interface.
Regards,
Andrevz
Jan 03, 2009 | Radware LinkProof Application (904627-cl3)...
Change passport
Are you talking about it asking for a Network Key or are you trying to login to the web interface of the router to configure it?
At any rate, if it's a network key you're looking for and you do not remember it I would connect your laptop to the router using a network cable and log into the web interface to reconfigure the key. All you need is the IP Address of the router which you can find by going to a command prompt (START MENU | RUN | Type CMD | Click OK) and typing IPCONFIG. Hit Enter and you will find the "DEFAULT GATEWAY". This IP Address is the address fo the router.
Put the ip address in your address bar in internet explorer or whatever browser you use. Log into the router. If you never created a password the default for most LINKSYS routers is a blank username and admin as the password.
You can go to the wireless security section and change the security key.
Hope this helps.
MO
Jul 18, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
192 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
