Question about Dometic Refrigerators
Dometic rm 760 rv fridge appears to not work on electirc side..........suggestions for either checking this condition or replacement
    Top Expert:
  • Dometic Master
  • 7,919 Answers
Bad heater element
Posted on Oct 14, 2017
erpaalai
  • 999 Answers
SOURCE: my rv fridge will build up ice and freeze food too cold
The thermister for the temp control is a likely culprit. Eric
Posted on Jul 07, 2009
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
motor1258
  • 6674 Answers
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
Posted on Jun 03, 2010
SOURCE: My Dometic rv Refrigerator does not cool the lower
If the freezers ok, then airflow is the issue, as the reefer gets its air from the freezer, set the dial that does not operate the compressor to the middle setting, pegging it to cold, makes the freezer colder by starving the reefer!, very common call requiring no repair , just a setting change!! never peg it!!
Posted on Jul 19, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
My 1987 dometic rm2600 works on electricity but not on gas. No light shows.
It is more then likely just a dirty orifice. The orifice is located just before the burner. It is a brass fitting that screws into the burner. It can be cleaned by removing it and soaking it in rubbing alcohol for a half hour then blowing it out. Do not poke anything through it! One cleaned try the fridge again, if this does not cure the problem then it is more then likely your thermostat that has failed. These thermostats are still available. They are a dometic dual stat and can more then likely be found on Ebay for around $100. For any other RV fridge issues please contact ArctiCold Refrigeration We keep it cold with locations accross North America we can help you with your RV fridge problems. ">
Aug 14, 2014 | Dometic Refrigerators
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
We just aquired a 1995 RV with a Silhouette
Should be a moedl number.RM -----# on fridge. Have that ready and go to: (www.dometicusa.com) . Click on customer support, then on left side you'll see Operation and installation manuals, click on that. Click refrigerators, for Caravans, motorhomes, RV's, and find your model and download PDF for copy of manual.
Jun 04, 2010 | Dometic RGE400 Top Freezer Refrigerator
I have a mid 70's Dometic RM 211 refrigerator in my camper. The screen on the propane burner has been damaged and needs to be replaced. Parts no longer exist from Dometic. What size wire mesh do you...
Hi Brian,
You don't want to use a screen that is made to fit. The original part was designed for a specific flame. That being said, colaws rv salvage may have a replacement burner in stock, and you can also try calling up a company that rebuilds cooling units for rv fridges.
Jun 03, 2010 | Dometic RM2193 Compact Refrigerator With...
Jul 06, 2009 | Dometic RM2620 Refrigerator
Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
May 18, 2009 | Dometic RM2620 Refrigerator
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
530 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
