Question about Samsung BDC5500 Player
It will not turn on. Neither on the front panel nor with the remote,
    Problem Solver:
  • 26 Answers
Take the case off and there should be two fuses inside take them out but replace with the same voltage and amperage if not then you may need to change the power transformer
Posted on Sep 21, 2011
Can turn on the tv from front panel swith. component inputs work. composite inputs and remote control do not work
Point the remote at your cell phone camera and press a button on the remote. You should see a purple pink light appear in the image of the camera. If you don't, the remote is bad.
Feb 05, 2016 | Televison & Video
Have zenith tv with zenith remote working fine. Wrong buttons were pushed trying turn off tv in the dark. Now remote doesn't work. Good batteries. H24F36DT. Ztv. And Zenith tv remote! Non universal..!
I don't have one of these, so a couple of guesses: turn on TV from front panel and attempt to turn off from remote. If that doesn't work turn on TV from front panel and look for setup menus which may have gotten trashed somehow. Take batteries out of remote and leave out for an hour. to see if it resets itself. Have you called Zenith help line?
Service manual: http://www.go-gddq.com/upload/2009_08/09082716157372.pdf
Feb 08, 2015 | Zenith Televison & Video
LG 55le5400 remote does not work, front panel does not work, it's stuck on one of the OTA channel. All the lights in the front panel are on. fresh battery on remote. the only way to turn off is un
If you do not have the owner manual either Google the model number for it or contact LG.
This set may have a lock out feature that locks out both the remote and the buttons on the set.
Also if have not tried it--unplug set for a while and power back up which may allow it to reboot.
Jun 10, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Tv has worked for ever with the remote now remote has failed and the on off swutch doesnt work to turn it on and off How can I program another remote if I can turn it on?
First, check to make sure the front keyboard is not locked out. Press and hold the menu key for 10 seconds then release. If it was locked out, then front panel buttons should work. If no change, you likely have a problem with one of the ten contact switches on that panel. Remove the front speaker grill by pulling it off, then trace the wires from the front control panel (you may need to remove the cover off the front of TV). Unplug the wires to the front panel and try by Remote control. If the remote works, you can purchase ten tact switches and install or just leave the wires unplugged and use it like that.
Bill W
integrityhomeworx.com
Mar 13, 2011 | Mitsubishi WS-65411 65" Rear Projection...
Can you turn off the FPA lock without an original remote? If so, how?
If you remember your pass word then you can use any remote that operates the TV to reset the menu selection. However if you don't remember the password, then sorry, the original remote must be used.
Below is the procedure to set up the menu for front panel lock, unlock and the password reset.
Front Panel
Selecting this option lets you lock (disable) or unlock (enable) the TV's front
panel buttons. The remote still tunes to any channel so remember to remove
access to any remote that can operate the television.
1. Choose Parental Control from the Main Menue and press the OK button.
2. Enter your passworcd.
3. Press the down arrow to highlight Front Panel.
4. Press the right or left arrow button to choose unlock (_) or lock (_).
I don't remember my password and I want to unlock the TV
If you forget your password, you must reset it. Make sure the TV is of. Press VOL- (down) on the TV's front panel and then
CLEAR on the remote for approxhnately 5 seconds. The TV turns on. Enter a new password next time you access
the PARENATAL CONTROL menu or the TIME_menu.
Feb 17, 2011 | RCA 20F512T 20" TV
Locked tv set model f19421
These are the instructions on locking and unlocking the control panel for your TV: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 12, 2010 | RCA F19421 19" TV
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Samsung BDC5500 Player Logo
121 people viewed this question
Jerry Greenberg
Jerry Greenberg
