Has an OCE copier & scanner; the scanning function to the computer has stopped working. Owner has check the settings and turned the maching on & off but still unable to get it to work right. Please advise.
  • 2,574 Answers
Are you able to do copies from your OCE copier ?
Have you tried conneting to different USB Port ? Also, when did this problem started?
Which OCE model do you havE?
Posted on Mar 25, 2011
Oce tcs500 scanner - error code 10514-246 scan failed. any solution for fix?
Repair of oce scanner with error code 10514-246:
The customer Service said that this error means there is not enough light reaching the camera and we have to let them replace the lamps. cost:1500€ :(
solution: i removed the backplate of the scanner (3 screws) and cleaned the lower mirror. it was that dirty that i nearly didnt find it. it is placed on the groud of the lower big hole behind the backplate.
After that i recalibrated the scanner and now it works fine again.
I hope this helps since there is no correct exlanation of this error on the web.
Nov 01, 2013 | Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
I need an Operator's Manual for the OCE CS 4035 scanner.
Google it, they have it. I found the manual for the Oce' copier so I could check out the scanning mode. Hope this helps.
Mar 18, 2011 | OCE Office Equipment & Supplies
My oce 4780 scanner has a problem, it warms up ok then I scan a couple of maps then the maintenance and clock light come on. If I turn off and on it will eventually go away, but the help on the oce scanner...
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Mar 14, 2011 | Computers & Internet
Scanner
Begin with installing the driver device, check the conflicts in computer, check the cords, work with computer, bad таботают such device with long USB cord.See in panels of computer management comsumed facility of the scanner, see the tests, this has an ensemble of the decisions, arouse all do anew. Good luck!
Aug 11, 2009 | Toshiba E-STUDIO 450 Copier
Scan function not working
I have had issues with HP scanners myself. The way I deal with this is to use the scanner and camera wizard in XP, it recognizes the device and scans even over the network. Works every time for me.
If you need more help let me know I CAN solve this problem, let me know.
Jim
Aug 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
I am using windows xp and I am having problems scanning using HP officejet L7590. I can print with no problems
http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/product_pdfs/3643611.pdf
this is an user manual ..complete edition ...save it ...and read it well .cause if you can print it means that isnt a driver problem ...but just your skils with it ...I hope this will in-light ya ...
Jul 18, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
MY SCANNER DOESN'T HAVE A SCAN BUTTON && I DONT KNOW HOW TO SCAN!
try scanning through your printer/scanner program on your computer. This worked for me
Jun 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Scanner stopped working
check the windows firewall or antivirus.may be blocking the scanner
Apr 29, 2009 | Office Equipment & Supplies
Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
May 28, 2008 | Canon imageRUNNER 5000 Copier
62 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
