Question about Sony KP-57WS500 57" Rear Projection Television
Is the picuture tube messed up when you see double people and the color is faded
  • 643 Answers
That usually means your convergence ics are going out. Replacing those will get rid of the double imageing. If the color is faded realy bad that means your tubes are going bad. That repair is pretty costly. Tvs over ten years are usually money pits.
Posted on Mar 26, 2011
Picture colors keep fading
U have tools like a soldering iron and roll of solders?Fixed it by resoldering the tv video board pins connecttions sockets pins between tv video board and the CRT-(tv tube). Tv video board that the board where it is connected to the CRT-(tv tube).The video board sockets hole pins that connected to the CRT-(tv tube).Those video board sockets pins are coldsoldering resolders this video board socket pins to the CRT-(tv tube).Will fixed thiss video colors fading problems.
Jun 27, 2011 | Symphonic ST419E TV
My grandfather has a Hitachi 50ux58b and is having double vision or shadowing -- whatever it's called and redness color fading-like. Was told it was a convergence IC that needs replaced -- uncle looked...
try not to do repair yourself. the tv holds high voltage even when unplugged. you could KILL yourself. If red is fading the convergence ic will not help. you need to replace all the guns. red, blue, and green. usually each tube or gun is around 300 dollars each.
Mar 21, 2011 | Televison & Video
The color is fading. i almost can't see the picture at all. Everything is turning green
you should really see an electronic technician , your problem is not that bad , just electronic parts getting loose ( must re-apply solder to them ) and this will solve you problem , some calibration have to be done also !!
Mar 10, 2010 | Akai Audio Players & Recorders
MY SAMSUNG DLP MN HLP6163W PICUTURE HAS FADED
If you have had this unit for awhile it could just be the lamp. If the image does'nt brighten up you may have an issue with the light path. The color wheel produces the color. If there was an issue with the color wheel you would most likely have a black and white image.
Jan 24, 2010 | Samsung HLP6163W 61" Rear Projection...
The only issue with it is it has a double vision screen (The colors are kinda messed up)
JUST GET MAGNET AND TRY TO PASS IT BY THE SCREEN, OR GET IT CLOSE TO THE MESSED UP COLORS, I HOPE IT WILL HELP, LET ME KNOW IF IT WORKS
May 13, 2009 | Samsung PCH521R 52" Rear Projection...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
PCN5425R Fading in and out
No It is not the picture tube.
First, I would suspect a bad solder connection (cold solder connection) to find this problem hit the side cassing to see if the picuture goes away or comes back.
Another way is take the back cover off and tap gently on the boards with something not conductive or your hair would look like mine. The most commond section is power supply and neer the Horizontal flyback transformor.
The horizontal transformor look at it, it's a big greyish darty little thing about 3" x 4" and stand up about 4" with a big red wire going out of it. Don't touch it, it has very high voltages, just look what it done to my hair I'm telling you don't touch it along with it's red lead's. Just look to see if it is arking if so replace it.
When you have convegence problem , it is mis aligment of the colours in the genmentry aligments.
I would suspect more in the power supply section.
Regards
What about Bob
Timmins, Ontario
Home of Shania Twain.
Mar 08, 2008 | Samsung PCN5425R 54" Rear Projection...
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
Faded Picture
I would have to say it does sound like the CRT is reaching its end. The thing that points this out that the picture gradually gets a little bit better as it warms up. It most likely isn't worth the cost to fix it.
May 07, 2007 | JVC AV-27230 27" TV
Sony KP-57WS500 57" Rear Projection Television Logo
339 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
