Question about Estate EGD4300TQ Gas Dryer
My Estate dryer (EGD4300TQ0) will run continuously but will not cycle out. Also, it will not heat up?
  • 163 Answers
SOURCE: estate gas dryer model#TGDX640JQ2 running no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
dniro592006
  • 121 Answers
SOURCE: Whirlpool Estate Dryer TGDS840JQ1 dryer runs but
when you say heat up is it at least getting warm...
you may have a igniter gone bad or your thermostat may have failed... your igniter is what has to ignite the gas to burn to make it hot. If its electric then your heating coil has failed and needs to be replaced
Posted on Jun 09, 2009
dragonsthatk
  • 547 Answers
SOURCE: Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
  • 31 Answers
SOURCE: Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Posted on Jun 11, 2010
jsrock516
  • 5911 Answers
SOURCE: dryer won't heat
If your dryer still runs, but does NOT heat, the following two links explain how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet or Kenmore Elite model, the heating circuits are located inside the dryer under the dryer drum on the right hand side. You will need to remove the lower toe panel under the door to access. The toe panel comes off by locating and removing the screws under the bottom front edge of the panel.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is not the heating element. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Repairclinic.com has a repair manual that you can purchase that will also help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on Jun 25, 2010
Dryer does not heat
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Feb 18, 2014 | Estate Dryer Model Egd4300tq0 Thermal Fuse
TEDS840JQ no heat
It probably has a bad timer. To check the timer set your meter for ohms or tone if you have tone. Connect a test lead to the terminal that connects to the large red wire from the heater. Now check for continuity between that point and all other terminals on the timer. if ya cannot get a reading the timer is bad. Here is my video:
Estate Dryer No Heat
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 02, 2013 | Estate TEDS840JQ Electric Dryer
I have an electric dryer, Estate by Whirlpool, It runs perfectly fine on no heat, it also works well on the cool down cycle of a regular cycle. However, if you try to use it on anything else, when you push...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 16, 2011 | Dryers
Kenmore Elite Dryer won't start. Stopped in mid cycle. Timer replaced, still not starting.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 10, 2011 | Kenmore Dryers
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
My estate dryer is not producing heat throughout the entire dry cycle.It does initially, but not all the time.Saw heating element glow and flame up shortly after , but will not stay on and dryer will run...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 25, 2010 | Estate TGDX640JQ Gas Dryer
I have and electric estate dryer. The drum is turning but the clothes are't getting dried in the automatic cycle or timed cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 14, 2010 | Estate TGDS840JQ Gas Dryer
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Estate EGD4300TQ Gas Dryer Logo
127 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Terry Schneider
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
