Having problem locating the specs. for Armstrong SCU10B30A condensor capacitor. Is there a schematic or parts list available for access?
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: want to know capacitor specs.
The capaitors should be clearly marked on the original capacitors. You will find a voltage rating and an MFD rating printed on them. The rule is you can go 10% over but never under on the ratings.
Posted on Jul 11, 2008
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
Acoustic research subwoofer s108ps has a burnt capacitor
HI,
I'll let you know if the service manual is available for this model.
Jun 15, 2008 | Acoustic Research S108PS Subwoofer
Fan stopped working on Armstrong Heat pump outside it hums. Model SHP10B364A-2A. If this is a capacitor please let us know what kind we can replace it with.
Replace the deal run capacitor that is connected to the compressor and condensor fan. The uf and voltage rating will appear on its surface. If markings cannot be read look for schematic inside unit to give you info - if nada, contact manufacturer for specification.of cap.
Mar 12, 2015 | Heating & Cooling
I have a Armstrong air condenser unit model SCU10B30A-3 and i cant read the capcitor number to order a new one
did you ever get an answer to which capacitor to order... I'm in the same boat.
Jul 06, 2014 | Heating & Cooling
What size capasitor needed for a armstrong model scu10b36a
You need a Dual Capacitor 50+5, according to the specs. The one I most recently worked on uses a 35+5, though.
Mar 26, 2012 | Heating & Cooling
Heat pump Trane XE1000 needs new condensor motor and run capacitor
you could replace it yourself remove old mtr & cap. info. you need should be on body of each if not check unit call supply stores or local company for parts
Mar 22, 2012 | Heating & Cooling
My research has determined that the vertical filter capacitors or vertical output transistors are bad. I have the schematic and parts diagram for my tv but I do not see those specific parts listed. Any...
hi there ! schematic diagrams sometimes are not complete with such information.all you have to do is :
1. look for the defective parts .
2. determine the cause or is there any affected parts?
3. capacitors and vertical transistors does have value that is indicated on each parts which is very visible in our naked eye.
4. replace the defective parts and buy a new one .its available in all electronics store near in your area. thank you.
Feb 08, 2011 | JVC AV-32D302 TV
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
Hampton Bay Dehumidifier Model# HB50
CHANCES ARE THE DUAL CAPACITOR HAS BLOWN APART...YOU WILL KNOW THIS IF THE SIDE WALL IS RUPTURED. THE CAPACITOR IS LOCATED TO THE RIGHT OF THE COMPRESSOR MOUNTED WITH 1/4 HEX SCREW..PART NUMBER WILL BE 50150115N001..AROUND $17-21.00.
Jul 27, 2007 | Maytag M7DH45B2A Dehumidifier
Heating & Cooling Logo
813 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
