Question about JVC RX-554V Receiver
My roadmaster subs wont work with this receiver in the sub jack. What am I doing wrong?
    Brigadier General:
  • 8,546 Answers
They're passive speakers and the sub jack only puts out LFE Line Level. It's to drive an amp that drives a sub. Besides, it's a car speaker and needs an enclosure to separate the forward sound pressure from the rear sound pressure or it will partially cancel itself out.
Posted on Mar 26, 2011
My sub wont come on. but all the outher speakers work fine . cant figure it out?
I assume this is connected to a AV Receiver? There is generally a low level sub out, with an RCA jack. That should go to your sub input. The old subs had the speaker outputs on the back of the receiver connected to the sub input, and all the other speakers were connected to the sub, but that system hasn't been used in decades.
Jan 24, 2015 | Audio Players & Recorders
How to wire sw8mk2
Does the receiver, Have a (RCA) Jack on the back of the unit ,Where it is written sub out,If it does, You need what is called a sub conecter patch cord to hook up the sub.If it is a powered sub, If the receiver does not have a sub jack you can not hook up a sub to it.
Oct 11, 2012 | Denon AVR-1612 5.1 Channels Receiver
Sub wont work
sub has to be on output not input
Jun 08, 2010 | Audio Players & Recorders
No sub audio denon-1506 receiver
You have to let the Denon know it has a sub or it won't send anything to it.
I can't find the manual but I'm sure you could dig through yours and find the area concerning speaker set up.
Mar 08, 2010 | Audio Players & Recorders
How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Mar 01, 2010 | Yamaha RX-V559 Receiver
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Can't get my Accurian subwoofer to work
Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
If it is not working still; bring it back and swap it for another one before you warranty runs out.
Jan 28, 2009 | Audio Players & Recorders
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
Sub Woofer Won't Work
Connect the input from the powered subwoofer to the rca jack on the VSX-409D labelled 'sub woofer preout'.
Dec 24, 2007 | Pioneer VSX-D409
JVC RX-554V Receiver Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
