Question about La Pavoni "PROFESSIONAL Chrome" 16Cup
Hi, My la pavoni is quite clogged and water is no longer coming through in a shower when I rinse through (ie. when no coffee attachment fitted). this in turn makes coffee come out very slowly and sometimes I now need to lift lever twice to get one shot of coffee. I would like to take it apart however I can't figure out how to. Do you have a link to a manual that I could download which shows how to do a full clean/service on the machine? Much appreciated. Hugh
5 Suggested Answers
JetJedi221
  • 25 Answers
SOURCE: Cleaning La Pavoni Burr Coffee Grinder
You'll need to remove the hopper and grind out all the beans. Then, with the lock tab depressed (if it has one), unscrew the grind adjusting collar out of the body. Once it's out, there are three screws (sometimes only two) holding each burr. Remove screws and separate the burrs. Clean away!
Be very careful putting it back together so that you don't cross-thread the collar into the body. Clean threads can help this.
Posted on Jan 08, 2008
mirran
  • 515 Answers
SOURCE: la pavoni professional
Make sure your filter is clean.
Posted on Jul 22, 2008
SOURCE: Clogged shower disc
We have the same machine -- the Italian grocer who sells us our coffee recommended the following and it worked really well for us:
use a blowtorch -- we have one of those kitchen ones for creme brulee and the like -- however, you will notice slight blackening of the disc -- otherwise the disc is fine. Shine the disc in the light to ensure all holes clear. Blast it again if necessary -- gets hot so ensure you have protected your hands etc...
Posted on Apr 28, 2010
guru_fixya
  • 944 Answers
SOURCE: I bought a LA PAVONI
This problem could occur due to to two problems.
1)Blockages in the valves.There are many valves present that will cause this issue.
When it is blocked due to dust particles it will block the flow.Check in the the diagram of how
to separate the La Pavoni.Apply some air pressure at the valve knob endings and the flow turnings.
2)Piston may to block the flow.So take it clean and place it properly.
Here is the parts diagram which will help you take apart the La Pavoni.
For clear picture and more details:
http://www.lapavoni.it/PDF/RIC_EuropiccolaProfessional.pdf
http://www.google.co.in/images?um=1&hl=en&tbs=isch:1&&sa=X&ei=_PCRTIzsCsT68AaylNXABQ&ved=0CCMQBSgA&q=La+Pavoni+Europiccola+parts+diagram-1&spell=1&biw=1152&bih=672
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 16, 2010
I need the order for the 3 wires on each 0f the 3 swithes ? on a epl 12 !!
Hi this link goes to a site that covers quite a lot of stuff about Pavoni lever machines hope you find what you need. I have set the link to land on a page that has a wiring diagram,
Powering up the La Pavoni
Aug 06, 2014 | La Pavoni Coffee Makers & Espresso...
Hi there. problem with my La pavoni PL-16. No coffee comes out. The vapour its ok, it comes out but from the place the coffee should comes out, it doesnt. With or without the the filter holder. Whats...
Hi if there is Vapor coming from the grouphead when the lever is down then I would guess there is a problem with the seals around the piston and possibly elsewhere. Here is a link to a goos site that looks at repairing La Pavoni lever machines. Good luck.
DIY
dr pavoni
May 29, 2014 | La Pavoni Lusso PL-16 Espresso Machine
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
La pavoni professional
Jul 21, 2008 | La Pavoni PC-16 Espresso Machine
La pavoni 8-cup espresso
Hi.
Will it go on at all? You should be able to turn it about 1/4 turn to the left once it's on. How far can you turn it, if at all?
I'm not sure which filter you're referring to, so I'll cover both:
1. There is a shower screen in the brewing group of the machine. You would have to look up into the group from below, in order to see it. This should be just a press fit, it's held in place by a big O ring. If it's lopsided, you should be able to just push it back up into place.
2. There is a filter that sits in the basket. It's the one that you fill with coffee. It should just sit square in the basket. If it's lopsided, take it out and you should be able to see why it won't sit in there properly.
Fergus.
Mar 15, 2008 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Losso Espresso machine not working.
Fill the tank with a strong De scale soulition , sounds like its blocked with limescale. REMEMBER to rinse thru clean water several times after the process...
Feb 08, 2008 | La Pavoni Lusso PL-16 Espresso Machine
Europiccola
Use (2). And you could back it off by 1/4 turn, rather than 1/2 turn I think. You want the piston to almost touch the screen at the bottom of its travel. You don't want the piston to push the screen out.
Fergus.
Dec 20, 2007 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Pavoni Si - leak from above filter holder
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Oct 09, 2007 | La Pavoni Espresso Si PAB-16 Espresso...
La Pavoni "PROFESSIONAL Chrome" 16Cup Logo
63 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
