I have a little white plastic piece that fell out of my wii when i took it apart no idea where it goes and the drive does not spin
  • 436 Answers
Can you post a picture of it?
Posted on Mar 25, 2011
What have i done?
Those wheels go on the left of the drive to keep the disc in or eject. Here is a like to a drive tear down. SLB Nintendo Wii How to Repair the DVD Drive Guide
Apr 27, 2014 | Nintendo Wii Console
I was replacing the disc drvie laser and gears and other plastic fell off the side and i need to put it back together
Gears are a little difficult if you dont know where they go. I would purchase another drive working or not and just look at how those gears are placed. If you have about a 1/2 in long white piece it has no big purpose just holds the ribbon for the top lid down.
Feb 18, 2011 | Nintendo Wii Console
Opened up my wii and a part fell out, can't find where it goes. Small white plastic piece, was sitting in front lh corner looking from front.
youre lucky it may have been really important just leave it put the wii flat and try it if it fails to work seek expert advice
Jan 28, 2010 | Nintendo Wii Console
Wii would not eject disk so we took it apart and fixed it but while we were doing this a plastic piece fell out of the metal casing over the disk drive now we cant find where it came from so we are now...
what does this "plastic piece" look like??
that said.. I think its the magnetic disc holder (round- white- plastic- fits on a cd...)
, it sits on top of the disc drive in the round hole - it holds the disc to the motor when the disc plays...
You have to put it back in its holder above the disc, it goes on top of the "crossmember" if you put a disc in the drive and set the laser to lift up and grab the disc you will know if you have it right because the "plastic piece" will grab the disc and hold it tight against the motor.
hopefully this solves your problem... comment back if you need more info or if the p[iece isnt what I described and is something totally different.
Jan 21, 2010 | Nintendo Wii Console
Wii Drive Levers
Without the springs your pretty much screwed. They are kind of important in the grand scheme of things. Without those springs you won't have to worry about reassembling it. If you find them, here is a Wii dissasembly guide. Follow it backwards to reassemble. http://www.xbox-modchips.com/wii-tutorials/xcm-wii-dissasembly-guide.htm
Nov 26, 2008 | Nintendo Wii Console
Kenmore...no drain but clicks instead...agitates and drains fine 110.92195110
not sur if you found your problem bu I found what was happening with my washer. I pulled the trans and motor assembly out and found a plastic gear / cam broken. I think the part number is 64194. it's found between the clutch and drive to the drum.
Jan 06, 2008 | GE Profile WPRE6100G Top Load Washer
Soldering 'Card Cover Open' Switch Closed
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Aug 13, 2007 | Olympus FE-130 Digital Camera
Olympus FE-130
on the above image you can see how I solved this problem. I used the way discribed in solution #2. I first broke off the little box and then added the little copper wire contacting the piece of iron at its left. Now my camera works again.
Apr 12, 2007 | Olympus FE-130 Digital Camera
My screen keeps showing card cover open error.
Nov 17, 2006 | Olympus FE-130 Digital Camera
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
