Question about HP (344872-001) Laptop Cooler, Cooling Fan
At startup my fan is working, then it turns off and does not come back on even when the DV1029ap gets hot enough to shut itself down. Fan is a new one
  • HP Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 25, 2011
Custom build PC shuts down by itself
you are overheating.did you use enough termic paste ? your computer shuts down for so it not breaks the processor.se to at allways as few startup programs as possible.and invest in a new PSU.
May 28, 2013 | Abit KT7A Motherboard
2002 Suburban_ Engine off but air stays on. When engine is on a/c light stays on & ait stays on even if the fan is turned off
Fan will run for a certain period of time after shutting down motor of vehicle. This is normal. Your engine is still hot when you turn the key off. There are sensors that tell the computer when the engine is cool enough for the fans to shut off.
Jan 25, 2013 | Chevrolet Suburban Cars & Trucks
PC restarted by it's own. Temperature fast to hot
The system is heating up really fast is caused by not enough cool air being directed to your CPU, Turn off the computer un-plug everything from the wall and carefully remove the side panel, not touching anything on the inside, look for the fan should be clearly to see, after that look closely enough to see behind the fan if its all dirty and filled with un-known substances then it requires cleaning. you can remove the screws holding the fan in place to give it a light clean, and put the fan back on, before putting the side panel back on check to make sure the screws holding the lump of metal is tight, after all that turn the computer back on and it should remain on.
The main cause to why the computer shuts down is because the CPU gets so hot the computer automatically shuts itself down to protect itself from over heating and causing damage.
Jun 27, 2011 | Asrock 945GCM-S Motherboard
My laptop will startup but as soon as it reaches the loading for windows it shuts itself off.
The problem you have can be fan problem.
If the laptop is still under warranty you should take it to assistance.
Mar 01, 2011 | Computers & Internet
Range modle is KGSS907SSS01.when i cooking or use the oven, some noice come out ,until over is off or the temperature is down.
is it possible the coolant fan is running and has started making some noise ...the fan will come on at temperature request it has a thermostat to bring it on when the oven gets hot enough and will cool down...sometimes the fan will run even when you turn the oven off if it is hot enough until the temperature gets down low enough to shut it off...maybe this is what is going on and the fan has started making noise now and will need to be replaced.... good luck to you
Jan 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
I have a goodman cpe30-1ab we set it to cool the out side pump and fan run about 5min and shut down the power relay starts to buzz and the fan moter gets hot real hot. all three wires to the fan have 110...
This could be several things. First turn of the power and make sure the fan turns freely using a screwdriver or something else that you can reach the blades with. If they do not turn easily you may need a new fan motor. If the fan stops, head pressure on the compressor will go up until it trips the High Pressure switch. It will also make the fan work harder so that it gets extremely hot just as you describe. Let me know what you find and we can go from there.
Aug 23, 2010 | Goodman CKL30AR30 Air Conditioner
Acer Aspire 5570z laptop CPU Fan
me to !!
it's seem is the fun is broke
Apr 11, 2010 | Acer Aspire 5570-2067 Notebook
My televison keeps turning off after being on for about 2 min. bulb has already been replaced.
Sounds like it is heating up on the inside. If you take the back cover competely off you will see that you have 4 fans on the inside, 2 big fans one on each side, one to cool the lamp and either 1 or 2 little fans which are located on the electrical box on left side and sometimes one that is mounted behind the DMD Board which is located behind the engine assembly. Because it is shutting down it tells me that the fan to cool the lamp is faulty. What happens is the fan cools the lamp, if the lamp gets too hot the television shuts down to protect itself from damage. Because AKAI parts are extremely rare to find I recommend not attempting to even turn on the television until you are able to replace the lamp cooling fan. If you see it is spinning it doesnt always mean that it is working because it may not be spinning fast enough. Good luck in finding a fan for it.
Feb 20, 2010 | Akai PT50DL24 Television
Computer Randomly Cuts off
processor overheating. When it gets too hot it automatically shuts your pc down and boots it back up. Even if the fan is running, it could not be supplying enough cool air anymore.
Jul 27, 2009 | Computers & Internet
Turns itself off & gets hot -don't think fan is kicking on
Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
May 06, 2009 | Computers & Internet
Computers & Internet Logo
138 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
