Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Hello my dell laptop's WD 500 BEVT stopped booting. a technician took it out and since then i bought usb connector trying to connect my newly housed wd with my other computers. although it will be detected by the add and remove hardware, when i go to my computer it is not detected, hence i cannot retriecve my data if you could help me out i would be forever indebted to you thank you
  • ybalabin Mar 25, 2011
    thank you so much for the prompt answer!
    right now i am using an adapter cable for 2.5" satta HDD to usb 2.0
    i suppose, from what you wrote, that is not enough or the right way?
    Genius:
  • 1,288 Answers
You need to connect this using a sata cable and sata power lead to a spare sata port on your computer, t should then be recognised as a legitimate drive
Posted on Mar 25, 2011
  • 1 more comment
    thank you so much for the prompt answer! right now i am using an adapter cable for 2.5" satta HDD to usb 2.0 i suppose, from what you wrote, that is not enough or the right way?
  • graeme ian hunter Mar 25, 2011
    I think its related to the power requirements. If you look at most external hard drives ( which in effect this has now become), they need the transfer cable and a power supply, which is why you need to connect a sata lead and power lead in the same way you would a slave drive
  • ybalabin Mar 26, 2011
    i will buy them tomorrow and try again
    thank you very much for your help
Can I use 750GB internal hard disk for Dell 1640, which is 4 year old
an external hard disk is a better option for your computer.
benifit is that u can carry it with you and collect data with from another computer easily.
so go for external hard disk
Dec 01, 2012 | Dell Studio XPS 1640 Notebook
Why wont my laptop start with My Book?
disable usb booting in bios, set hard drive and cd ahead of everything in boot order
Mar 15, 2010 | Western Digital My Book Essential 1TB...
Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Aug 15, 2009 | Western Digital 500GB My Book World...
ESATA Connection problem with My Book & my laptop w/ Vista
Had the same problem with a WD esata 1TB drive and an HP DV6 laptop. Using Vista home premium. Lots of experimentation BIOS settings and driver update, and finally fixed it by trimming back a couple of mm of the plastic shoulders on each connector of the esata cable. A few depth measurements and it became clear that the connectors weren't going in deep enough otherwise. The cable was a Belkin of reasonable quality.
No problems now, but the drive is only recognized if it's connected at boot-up.
The core of the problem is the external casing of both the laptop and the WD drive enclosure. They're thick and keep the cable connector from going in far enough. Perhaps manufacturers of the cables or the esata devices are sloppy, or the standard isn't specified well enough. I've seen pictures of esata cables that have significantly different dept.
May 14, 2009 | Western Digital My Book Essential Edition...
Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Nov 17, 2008 | Computers & Internet
External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
May 12, 2008 | Western Digital My Book Essential Edition...
WD My Book Essential Edition 500 GB Exetrnal Hard disk , Intalling problems
dear eVoTech
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
oke
cropp
Mar 18, 2008 | Computers & Internet
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
299 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
