Question about Maytag Refrigerators
I have maytag MF D2561HES. The freezer is working but the top part refrigerator itself getting wormer and wormer and does not react to me pushing temp buttons. say I push 38, it holds for a 2-3 sec and switches back to the current, not qbout 68 and keeps growing.
5 Suggested Answers
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
  • 7 Answers
SOURCE: Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Posted on Dec 11, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Samsung Cool Tech Dynamic not cooling properly
Alan if the power was off for less than 5 minutes the compressor high pressure went to the low side and the compressor just will not start. The thermal overload Klixon will click about every 8 or 9 minutes and the compressor will not start.
Unplug it for about 30 minutes and then plug it back to see if it lites off and runs correctly.
As for the control panel... (fingers crossed) hopefully it is a symtom of the compressor not starting. Again unplug it for 30 minues and restart it after that. It just may get things back to normal without any repair service.
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: maytag mf d2561hes tries to start but just clicks
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
How do I clean the coils on my Maytag freezer-on-bottom fridge? (Model #i is MF D 2560HEW)
HI,
Pick up a coil brush from you home improvement center near you and remove the grill in the front under the freezer door. With the brush, brush the coils under the unit to clean them. Have a vacuum handy, you will need it for dust and hair if you have pets in the home. Good Luck
Apr 20, 2016 | Maytag Refrigerators
We have a Maytag Model # MF D2561HES, side by side, freezer drawer below. It is a quarter of an inch too high for the space. Is it possible to remove the wheels from the bottom in order to solve this...
The last one of these that I had that issue with could not be fixed that way. The only thing that you can do is remove the cupboard that is above it and use a table saw to trim 1/2 inch off the bottom of the cupboards.
Jan 20, 2014 | Refrigerators
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Hi. Maytag Refrigerator freezer is not working at all, hence the fridge itself is not cooling whatsoever. Is it that it needs freon refill? or is it time for a new fridge, after 6 years?
You might want to try cleaning the coils on the back of the fridge. You can either use a brush or a vacuum cleaner with a brush attachment. A second possibility is that the defrost cycle is staying on. Try replacing the timer in the freezer section. If that doesn't help then the condenser is probably bad. In which case it's time for a new fridge.
Aug 26, 2010 | Maytag MTB1976HR Top Freezer Refrigerator
Maytag mf d2561hes tries to start but just clicks and is warm
heatman101
Jun 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag freezer icing up
If is just one spot in the whole back wall like snow ball (small) ,the unit is leaking refrigerant and the leak has to be fixed and only after that recharged.But if the back inside the freezer gets all ice up and won't defrost by itself the problem is with the defrost system ,timer ,heaters or defrost terminator.
Aug 09, 2009 | Maytag MTB1976HR Top Freezer Refrigerator
Turned on to #9 and fridgeis not turning on and not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
b,mf,
Dec 23, 2008 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
