Question about Philips Cineos HTS9800W System
I have a philips cineos 42pfl9632d/79 TV. No picture but good sound can change chanels (sound) and everything else. The tv has been sluggish turning on for some time and the picture was good when it did work. Can you help? If something needs replacing ,where can I buy the modules/ parts from? regards Neville
  • 1 more comment
  • lloyd_south Mar 26, 2011
    Hi
    this is a philips flat panel TV no yoke etc. solution provided not suitable for this TV thank any other solutions?
    42PFL9632D/79
  • lloyd_south Mar 27, 2011
    Hi
    Sorry do not know what a HTS9800W is. My question was about a flat panel 42PFL9632D/79
    thanks. The problem has been solved so have ordered new inverter boards.
    Hi
  • Philips Master
  • 17,130 Answers
It seems that the TV has some components that can be weak in value and so there is a slow start in the circuits to build up the voltages or frequency to the desired level before the circuit works perfectly.
Now this can be due to lower values in capacitors which is most possible or even a fault in the semiconductor section- weakness of IC's.
If you think that the board works well after it heats up or the circuit warms up then you will need to simulate to confirm the sections.
Hence power off the set and remove the covers. Now clean the board from dust , dirt using a air blower. use a good light to inspect the board to check if there are DRY solder joints on the board specially in the power sections. Now use a dryer warm suspected sections starting from the power side. If you can also have a FREEZE-IT spray to bring down the heat the set will then demonstate the difference between the functioning on heat. This will enable you to confirm the section. Now try and change all the suspected components after you pin point the location.
This is the easy way without any technical support.
The other is to take a circuit test, check voltages , check insufficiency to confirm.
Posted on Mar 26, 2011
    Genius:
  • 1,622 Answers
Hi,you have lost vertical deflection.
Possible causes are----
Vertical amp chip needs re soldering.--- very common !
Vertical amp chip has failed and needs replacing !
Failure of electrolytic capacitors in vert circuit
Failure of resisters that supply volts to the vertical circuit
Failure of deflection yoke ( not very common )
Hope this helps
NOTE . If you come across the two knobs that the other dude mentions let me know. I am sure that my fellow Tv techs would also be fascinated to learn of their existence.
The problem you are describing appears to be a vertical circuit problem. The most common problem has been bad solder connections on the vertical output IC. If you inspect the PC board around the vertical ic, you can sometimes see the bad connections. Or the vertical IC and the associated capacitors in the circuit can be the culprit. Average cost to repair should be around $100.00 "
Posted on Mar 25, 2011
Why do i have no picture on my philips 42pfl9632d/10 tv. p
Can you hear sound? Is power light on? Where did the smoke come from?
Jan 10, 2015 | Philips Televison & Video
Phillips tv stand by button stuck no sound r pic mod.no.42pfl9632d/10
the model is phillips and picture above is Hitachi--the philips is not customer repairable--call around and get a estimate.
Oct 17, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Screen is black but we have sound
The problem is a faulty inverter kit (2 boards).
I live in the Netherlands and had it twice, tv is 2 and a half years old! In the Netherlands Philips replaces the inverterkit without any
costs for the consumer (even after warranty time) cause they have
admitted that it is a production fault.Philips made a new inverterkit
which should solve the problem indefenit.Be sure the kit is Version
1.3! I had 1.2 after the first problem, and that went wrong after 7 months again. Today got revision1.3 installed which is Philips final solution.
Jul 18, 2010 | Philips Televison & Video
I have a philips tv, its a 42" cineos, i have sound but no picture, can you help, or tell me the tv is any use, its only two and a half to 3 three years old
There are many issues that can cause that type of problem. Just take it in and pay the low cost for the estimate. It is well worth the money to do it that way.
Apr 10, 2010 | Philips Cineos HTS9800W System
Philips Cineos flat screen TV vith Ambilight 37PF9631D/10, went in standby and blinking red power led diode once-two times in cicles.
Sounds like an issue with the power supply board. We will have to go component by component and you will need to knowledge of using a multimeter. If you are skilled enough to do this then let me know and I will help you troubleshoot it.
Mar 19, 2010 | Philips 37PF9631D 37 in. LCD HDTV
Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Aug 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
42 inch LCD Philips TV - TV screen is black, but the sound comes through perfectly on all channels. Same result when a DVD is played into it. Model number 42PFL9632D/79. Plugged into a power centre...
hi sir
this type nof problem occurs mainly because of 3 issues...
1.jungle ic in D -board
2.colour wheel
3.cathgode ray tube/..please check them
thank u,,/please rate it
Jul 01, 2009 | Philips Televison & Video
Philips Cineos HTS9800W System Logo
383 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
