Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
How to adjust carberater - Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
    Scholar:
  • 54 Answers
There should be a small screw hole beside the prime pump bulb where you can adjust the centrifugal clutch nudge ahead speed, and then adjust down again for the correct idle without any chain motion. However the gas tank filter inside really needs to be cleared of a paper thin film of dust which gets in there while refueling and won't let gas through - this causes you to think the carb needs more gas or the idle setting is wrong.
Posted on Mar 26, 2011
Where can I find a husqvarna 240 e carb adjust tool ?
Before I change carbs, I think I would change fuel lines. Also always use ethanol free fuel.....the ethanol will eat and clog your lines!
Jul 12, 2014 | Husqvarna Forest & Garden No.967012396 345...
I have a ram 50 1985. the choke will not open on the carberater. what could be the problem
There should be a vac device called a pull-off that opens the plate about 20% when the engine starts. Then the electric coil heats up to open the plate in a few minutes of run time.
Sep 08, 2012 | Cars & Trucks
How do i fix my 89 jeep wranglers float in the carberater?
Carburetor floats are adjusted (if needed) when the unit is rebuilt. This is not a normal maintenance item and it is unusual for a float to become misadjusted. Rebuild kits for carburetors are available from parts stores inexpensively, and complete instructions for all adjustments and clearances are included in the kits, as well as all the gaskets and replacement parts you might need.
Jan 03, 2011 | 1989 Jeep Wrangler
What or how to adjust the carberater
I take it you just found a heading for your saw and it is gas operated, not electric? Adjusting the carb, you have 2 jets on the side , one low one high, depending on what it does, won't rev, won't idle, open up the adj screws 1/4 turn and see what happens, if they have been moved in and out and are way off, turn them all the way in and then out 1 1/2 turns each, this should get you running. You can fine tune from here, one at a time, and very fine adj. It doesn't take much. make sure the gas is mixed right, and the chain does not bind. Hope this helps.
Aug 16, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
17HP Briggs Intek engine ran good then quit. Now
Intake and exhaust valves need adjustment. Intake .004, exhaust .012.
look for wear or loose rocker arm bolt before adjusting valves.
Nov 22, 2009 | Briggs & Stratton Garden
New carberater and a mechanic needed!
Even if you do it yourself you need to adjust it.I would get another mechanic to look at it also.Have you tried cleaners? 1 type you add to the gas the other you remove the air bonet and spray into the top of carb while running (have someone press on the gas lightly so you don't stall.Have you tried to increase the idle via the adjusting screw? has the auto choke been tested..adjusted? Good Luck.
Sep 17, 2009 | 1984 Honda Prelude
The carberater is leakin gas
hi mate you float is to high in the carb take the carb off and take the bottom casing off and adjust the float to the correct measurements in the manual if the float is too high it is allowing to much fuel in and so it will flow over the over flow and out the tubes it is simple puch the pin out and adjust the metal where the little valve is hanging onto with a pair of long nose pliers good luck
Jul 07, 2009 | 2003 Suzuki RM 250
CARBERATER ADJUSTMENT ON A 330 HOMELITE SAW
There shouldn't be an adjustment to it. It is held in place with a pin & small piece of metal. The tiny spring goes under the small piece of metal and it hooks to the needle valve.
Jim
Jun 09, 2009 | Homelite Garden
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
61 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
